Question about Kenwood VR-5700 Receiver
How do connect two floor standing speakers to the reciever
  • 460 Answers
From the main speaker outputs on the reciever..
Posted on Nov 15, 2009
VE-15 3-way floor standing speaker. Why does one of the midranges produce little or no sound?
Definitely the crossover. Follow the wiring back to see where it connects and see what is on the board.
Nov 21, 2015 | Cerwin Vega Audio Players & Recorders
Morning I have a set of KEF Q 5 floor standing
I'd suspect a shorting voice coil in the woofer or a loose connection inside that vibrates and presents a wildly varying load.
Disconnect the bi-wiring jumpers and try driving each 'half' separately as a test for tripping the amp.
Jun 07, 2011 | KEF Audio Q55 Speaker
Hi i have a set of 203 JPW floor standing hifi
remove grill and approximately 6 to 8 screws hold speaker to box. Follow appropiate wiring in removal as replacement. Check crossover while you have it appart
Mar 08, 2010 | Sony MHC-RV888D Shelf System
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Need to find a cerwin vega 6 1//2 mid range woofer model number v-6f but i would like just the speaker only not the whole floor stand
muz782,
Replacement drivers for home speakers are only sold directly from Cerwin Vega. If you can find one online, it will not be authentic CV.
http://www.cerwinvega.com/contact_us.php
-Chris
Feb 11, 2010 | Cerwin Vega V-6F 6 1/2" 2-way...
Picture no sound, was floor model, never used till now, has been in storage, do we need speakers??
If it has an rca jack at the back that say audio out, try connecting that to a recievers input. If the sound plays on your reciever that means the sound processor inside works, at least at the small signal level.
Nov 25, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Location for Bose speakers 901
You could, but the boundary effect of the speaker being on the floor will change how the sound is radiated into the room and therefore make the EQ less effective. Best bet is to try to find some sort of stand (maybe even make one out of wood) that put the 901 at the same height the stand would of that came with the speaker.
The speaker and the EQ are designed and engineered as a system.
Look online, the manual for the 901 shows them hanging from the ceiling also as an option.
Dec 23, 2008 | Bose 901 VI Main / Stereo Speaker
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Jan 14, 2007 | KLH HTA-4100 System
Kenwood VR-5700 Receiver Logo
163 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
