Question about E-Machines eMachines Desktop PC
When I plugged in a flash drive. The computer went to power save mode. how do i get it out of power save. Is this a precursor to something else going wrong.
It could possibly be somethin in the flash drive. I recomend taking out he flash drive the restarting the computer.
Posted on Nov 15, 2009
I need help in accessing the memory of my 32GB flash drive to transfer files into it or to retrieve files.
Depending on the computer you have but it should be the same
first insert the flash drive in to the usb port
a window will pop up that say open to view or transfer photos or use as space to speed up your computer you can choose which ever you find that you need. now when you are working on any project and are finished go to the top left corner and click save as and then click on the drive the flash is plugged in to name it and save. It will be saved on the flash drive now when you want to get something form the flash drive click on the drive and choose hope this helps.
Jun 30, 2012 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
How do I keep my computer from going into powersave mode and crashing when I play games?
The computer is changing the screen resolution to a mode unsupported by the monitor. The "power saving" message is being generated by the monitor/tv not the computer. Check device manager and ensure that under displays, that you do not have "standard vga" I shall try and make a screenshot of what you need to look for or a youtube link.
May 24, 2017 | Gateway FX6800-01e PC Desktop
Freedownloads how to get your downloads to flashdrive so i may install to desktop that is not on line with xp servicepro 2
Assuming you already have a flashdrive plugged into the computer with an internet connection, go download a program you want, such as Google Chrome. When it says "Save" or "Run", choose save and save it to your desktop. Once the download is complete, and before installing the program onto the current computer, open the start menu and go to my computer. Plug in your flash drive and it should appear in the My Computer window. Open your flash drive and move the window such that your file on your desktop is visible. Now click and drag the file on your desktop to the flash drive. Once the transfer is complete, remove your flash drive and insert it into the computer that does not have an internet access. Then go to my computer, and locate the flash drive and open it. Move the window such that the desktop in in sight. Click and drag the file from the flash drive to your desktop. Then remove the flash drive and install the program.
Hope this helped, Nathan Taylor
Jul 17, 2011 | Microsoft Windows XP Professional
I have a logitech flash drive that is not picked up by my computer when I slot it into the USB port - I went to my computer and checked under disk management but it is not even coming up under there - do I...
Hi.
USB flashdrives are usually all plug and play so you don't need any additional drivers for them.
Try plugging the flash drive into a different computer. If it works on another computer your USB slots maybe faulty.
If the flash drive is not picked up by another computer then the flash drive is probably faulty.
Regards.
Jun 07, 2011 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I plugged in my PNY 4 gb 2.0 Flash Drive into my computer. I saved some photos to this source. Now that I am finished, do I just remove the flash drive or is there something I should do with the photos...
the photos are saved their now, simply remove the drive, but first go to the bottom right corner of your screen and find the icon that says safely remove hardware.
Jan 26, 2009 | Computers & Internet
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
My LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Oct 13, 2008 | Computers & Internet
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
