Question about Food Processors
When ice maker is on there is a clicking hoise
When ice maker is on there is a clicking noise from box with switch in it
and wont make ice
    Sergeant:
    Champion:
  • 289 Answers
Gear's are bad. you would be better off buying a new one.cost of service call and repair would exceed worth of unit.
Posted on Nov 15, 2009
Wont turn on. Wife was making something that put a strain on the food processor and it just stopped.
Hi!
Check the power source or the plug. It might be that the power source is not stable or check the plug if it has loosened or not. Or, check if your wife has something too hard processed inside esp. ice cubes (as she may need to pound it into smaller pieces). Also, let her try to adjust the mode.
Hope it helps.
Aug 15, 2011 | KitchenAid Food Processors
The motor popped when I first used it. I had a US version (110 volts) and plugged it into Australian plug with adapter at 240 volts. Any ideas?
All the adapter did was enable you to put 240VAC straight into your 110/120VAC coffee maker. You needed a step down transformer to drop the voltage from 240 to 120 VAC. This is not what you wanted to hear but you have damaged your coffee maker substantially by using the wrong voltage. Also the US version is designed for 60 HZ power vs AU 50 Hz power unless stated otherwise on the input power data plate.
Damage that has probably taken place:
1. Motor PN 8211837
2. Relay and Switch assembly PN: 8212011. .
3. Capacitor PN 8211608
Cost to repair... will be close to total replacement value due to shipping costs & customs of replacement parts
Thanks for choosing FixYa,
Kelly
May 13, 2011 | KitchenAid KFP750 Food Processor
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
I bought a peanut butter maker (model #PBM-200) for about $85 and it does not work. After trying several times I even tried grinding up the peanuts in a food processor before putting them in the peanut...
Where did you buy it? Return it, pretty much everything you buy has a certian warranty. Get your money back or replace it with a new one...............
Jan 04, 2011 | Food Processors
What is the purpose of the washer and where does it go on the Oster kitchen Center food grinder or pasta maker? I keep them both in the same box and I'm not sure which one the washers go to. Thanks
The purpose of this washer is to reduce the friction between the auger and the body of the grinder head. During the grinding process the auger is pushing food/meat forward to the disc and respectively reacting itsef backward. So, the washer goes over the back shaft of the auger as a surface of the contact with the body. You have to put it over this shaft before assembing the auger with the head body. The pasta maker attachment and the grinder both have identical augers.
Apr 10, 2009 | Rival 2275WP Food Processor
Food Processor won't turn on?
Food processor housings MUST be assembled in a certain order. And each part usually clicks or snaps into place. When all parts are PROPERLY assembled, the safety interlock switch will engage. Until then, no workee.
Mar 05, 2008 | Food Processors
Food Processors Logo
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
