Question about GE JVM1190 Microwave Oven
GE Spacesaver microwave trips the circuit breaker
I have a Spacesaver that seems use 1.58 KW. Now and then it will trip the circuit breaker, which is a 15 Amp circuit. I suppose it is not rocket science to see that the 1.58 KW takes the whole 15 Amps and blows the breaker, but I am wondering if there is any way short of rewiring a 20 Amp circuit just for this microwave to cut down on the load this draws, and still have it work.
I do notice that the particular breaker switch is somewhat loose in its slot in the box. That may be a factor, but I don't know. The kitchen lights are on this line as well, so we try using the microwave with no lights on when it acts up, but it still will blow the breaker, once it starts doing it. It works for a bit, then blows it.
I don't think just reducing cooking power will help, as I think that just cycles the main tube on and off.
Any ideas here?
  • Anonymous Jan 29, 2008
    COMES ON TURN TABLE TURNS BUT NO HEAT AND CANT SE TEMATURE SETTING
  • Anonymous Mar 24, 2014
    was able to set clock,. but nothign else works - blows circuit breaker when try "start."
  • GE Master
  • 9,098 Answers
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
    Problem Solver:
  • 7 Answers
*****HELP PLEASE****
My GE spacemaker trips the breaker too. It has it's own breaker. After checking the outlet with a lamp, I changed the fuse but that is not the remedy. If the micro's door is closed I can flip the breaker on and it operates/cooks fine even withthe interior light on but has the word RESET on the readout just above the control touch pad. When on if I attempt to program a cook time, none of the key pad works but the word reset does disappear. Soon as I open the door after cooking, the breaker trips again when I opoen the door.
I will try the outlet suggestion with the toaster and see if the outlet can handel the watts/amps. If not the outlet wiring or outlet itself, I am open to other suggestions.
Please go easy on me....I am a single disabled mother who is playing Mrs. Fix It, but I am known as the Martha Stewart and Norm Abrum/Bob Villa of single moms. I have more power tools and knowledge than most men (thanks to my deceased father who was a contractor) but electrical is a bit more challenging for me expecially when attempting to diagnose.
Thanks ;)
Posted on Mar 19, 2011
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Breaker trips when using microwave. Electrician can't find electrical problem. Could it be the microwave itself?
Answered earlier, another tips is to disconnect the power to the board and see if the circuit breaker holds, if not check the main line circuit.
Jan 31, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave: model 1840 circuit breaker trips when strarting micro wave
Circuit Breakers do weaken over usage. It is not usually a time factor as much as a load factor. Each time a circuit breaker trips, it loses its ability to carry the same load as it did previously. In other words, a 15 amp breaker only carries the ability to carry 15 amps once. I recommend replacing the circuit breaker with one that has a matching rating. If you do feel up sizing is necessary, check the load rating of the appliances to make sure the additional size really is necessary. Increasing power to appliances that shouldn't need it increases the risks of potential electrical fires and masking real issues. Try changing it with higher amp breakers.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 27, 2010 | Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I keep reseting my 15 amp breaker daily. I even moved the unit.
No. The unit is only supposed to pull 9.1 amps. (wattage divided by voltage equals amps) Your unit has a short, or your breaker is bad. Turn on the unit, when it trips the breaker see if the breaker is hot, If so, thats an indication the breaker is bad.
Apr 11, 2010 | Danby DMW112 Microwave Oven
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
GE JVM1190 Microwave Oven Logo
1,686 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
