Question about HTC Touch Cellular Phone
Will not load past the windows mobile screen
Is there a safemode? Or a way to push start this device all my info is locked in it
I get past the emachines logo then the setup but after that there's a dash on the top left of the screen and nothing happening after that
Usually if your seeing the dash on the upper left corner it means it's still trying to load the Operating system (example: windows XP or Vista or Windows 7) of your computer . If it really stuck on that part, try to do this step
1. You said that you just finish the setup, so we need to know if the setup is completed or successful
2. You need to restart your computer either by pressing reset or the on/off switch
3. Before you get to the e-machine screen you need to press on F5 on your keyboard for 3-5 times
4. You should be getting a screen that will give you options like this
Safemode
Safemode with networking
Safemode with command prompt
5. You need to choose safemode and usually it will load the page of windows if the setup is completed or successful
6. If it doesnt load then you might need to have it reinstalled because chances are that the setup failed and not all the files we're installed causing your windows not to load completely.
Hope this help you a bit.. Have a great day.
May 18, 2011 | E-Machines T2240 PC Desktop
Its not loading to windows, what should i do?
If its not loading to windows,check first what would be the error message or to make it more easier try to reinstall the Operating System of your machine, just access the recovery manager. Hope it helps. =)
AnEspera
Apr 18, 2011 | HP Pavilion dv6000z Notebook
ACER ASPIRE 5532 LOCKED UP, WON'T GO PAST THE "ACER empowering people" logo at startup. press f2 and it says "please wait" then won't do anything else. Pressing f12 to change start-up...
1. Turn the Laptop off 2. Remove the battery 3. Disconnect the AC adapter from the laptop 4. Disconnect any peripheral devices from the laptop such as printer usb cables, PCMCIA cards etc. 5. Push and hold the power button for 60 seconds then let go 6. Connect the AC adapter to your laptop 7. Push power button to turn on the laptop 8. If this resolves the issue shutdown the laptop connect the battery and turn laptop back on
If issue is not resolved restart the computer and begin tapping the F8 key repeatedly until you see a screen that gives you options to enter different modes. Highlight "Safemode" and press enter. If the computer boots completely into safemode you likely have a driver that has corrupted or a hardware device that has failed. Likely driver failures are video card drivers. Got to Device Manager and uninstall the video card driver and restart the system. You can do this with other drivers as well.
Mar 05, 2011 | Acer Computers & Internet
Computer start up is hazy and it shows a blue screen of death with crash info about video device driver glitch and device malfunction. need assistance ASAP
If your display driver is the real problem, you can remove it by going into safemode.
Restart your PC.
Keep tapping F8 once you see the post screen
From the Advanced Boot Options, choose SafeMode
When inside windows, right click on My Computer and select Properties.
If you're in Windows XP, go to Hardware tab and click on Device Manager. In case of Vista, click on Device Manager in the left pane
Under Display Adapters, right click on the entry and choose uninstall.
Restart your PC.
If you need drivers head to nVidia
Dec 21, 2009 | Acer Aspire L100 PC Desktop
The hp 6735s laptop wont start up?
Have you tried to start in fail safe mode? try push f8 before vista screen and after bios screen. choose safemode. does it start ?
Aug 17, 2009 | HP Compaq 6735s Notebook
Screen goes blank
Try to load to safemode by restarting the pc and hitting F8 before loading the windows, after you load to safemode right click on desktop screen and hit properties and check if you change the size of screen?or the setting there? also look for the device manager of your vedio card and check if it works properly.
If all this not working this means your vga converter has problem this is card inside your laptop mostly happen with dell laptops, if you donot want to change it now, try to see if you have external screen port and connect your laptop to external screen.
Let me know wat happen?
Best Regards
Mar 02, 2009 | Dell Inspiron 9300 Notebook
Cant get into windows at all
You might try turning your floppy drive off if you have one.
Nov 25, 2008 | Acer Aspire T120 PC Desktop
Hello, I'm wondering if you could
Try reinstalling your windows OS.
Oct 02, 2008 | Siemens Computers & Internet
HTC Touch Cellular Phone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
