Question about Whirlpool GS460 Gas Kitchen Range
Whirlpool gas oven won't heat to proper temp. Biscuits at 450 take an hour and 15 mins to cook and brown. What could it be?
  • 187 Answers
The oven has a temperature sensor inside. The sensor tells the oven when to go on and off. It may need replacement. The sensor is protrudes from the back left wall of the inside of the oven. Make sure that it is fully plugged in and that it is not covered with any goop from the oven. The other things you can check is that nothing is obstruction the heat. That means NO foil or coverings on the bottom of the oven. It blocks the heat vents and can damage your oven. Underneath the floor of you oven, you will find the gas jets.The flame should come out blue and steady. It it is sputtering and orange, the little holes might be blocked. Clean carefully.
Posted on Nov 15, 2009
Testimonial: "Thank you for your input. It was very helpful. Unfort. we had to replace the entire oven due to several problems."
How long will it take to cook a 15lb. turkey? From the Utube, I saw 30 minutes at 450
Just cooked a 15 pounder with stuffing wrapped tightly in foil on a rack in a roasting pan at 450 degrees 1/2 hour then dropped to 350 for 4 1/2 hours in a convection oven, the foil keeps the moisture in. Uncover last 1/2 hour for crispy skin
Nov 23, 2017 | Grilling
How long in the oven and what temp for medium rare what temp for the oven to be set at
A lot depends on the oven itself, whether it is fan forced, how well it holds heat etc.
Preheat to 240°C/475°F/ gas 9, place the meat in, and turn down to 200°C/400°F/gas 6. Cook it for about 1 hour, then take it out and place it covered on the serving dish for 15 min. before carving. This first go may need to have slightly modified times for the next roast you cook.
To get a perfect result you really need a meat thermometer
http://i.stack.imgur.com/blUvw.jpg
You don't need to put this in the oven with the meat, just insert the tip to the middle of the roast when it gets near time to see what is happening
Medium rare (? point) warm red center; firmer 55-60 °C Medium (demi-anglais) pink and firm 60-65 °C
Jan 07, 2016 | Omaha Steaks 2 1.5 lb. Tri-Tip Roast
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
Oven not cooking at correct temperature & loses heat
Had a similar issue - but my unit is eight years old. Turns out my issues were my oven ignitors were failing and one of the burners had corroded causing the flame to only light on one side. To fix I replaced two ignitors (apparently they are to be replaced every 3-5 years) and cleaned the burner with a brass wire brush. If you are handy the ignitors are easy to replace - one screw and two wires each. Burner was one screw to remove.
Ceramic ignitors if wearing out can cause delayed lighting of the oven burners and/or reduce the gas flow - hence not heating up.
That was my experience ....
Jan 11, 2010 | Viking VGSC366-6B Gas Kitchen Range
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Oven won't work
just go ahead and change to glow ignitor it is between 40 and 80 bucks
Dec 30, 2008 | Kitchen Ranges
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
391 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
