Question about Konica Minolta bizhub C250 All-In-One Laser Printer
How do I set Department ID code ?
I would like to know how I can manage the prints using a security code/Department ID for about 5 employees.
  • 589 Answers
Do you have the user manual for it? If you do, please refer to page 2-30 (chapter 2, page 30) to program user passwords. If you don't have it, let me know, and I will guide you through it.
Posted on Jan 09, 2008
Our canon C3220 is not printing from one of the computers in the office. It is putting all print jobs on hold due to authentication required
Auth Required sounds odd. The only thing i could think would cause this is if the copier itself has Department Managment enabled. This is used to limit printing by quanity and sometimes restricting color prints. IF everyone else in the office is required to enter a code to print and this one does not then you need to enable department ID via the driver settings. Right Click your print driver and go to properties and select "Device Settings" from the tabs on the top of the window. Under this menu there should be a box that says Department ID select that and try it out. Another way is to "aquire" the copiers device status a button labeled somewhat to this effect should also be in that same window.3_15_2012_4_29_14_am.jpg
Mar 13, 2012 | Canon imageRUNNER C3220 Color Copier
Im having a serious issue tring to get my kyocera fs-c5030n to print. I try to print, and it doesnt prompt for a password, but all that comes out if the printer is invalid account id everything I try to...
1. Click Start > Printers and Faxes
2. Right click the Kyocera printer and select properties
3. Select the "Device Settings" tab
4. Click "User"
5. Enter your User Name and Department Code
6. Click OK, OK
If you don't know the User Name and Department Code, these can be programmed by using the "KMNet Viewer" software utility, you can download it from here:
May 04, 2011 | Kyocera FS-5025N Laser Printer
How to access IR22016 configuration using IE? i want to setup dept. ID and password using IE.
Print a user data list.
Find your IP address. Enter the IP address into your web browser. This will present you with the RemoteUI interface.
Go to additional functions and select department ID management.
You can also do this on models that have a touch screen by pressing additional functions and pressing the department id management button.
May 06, 2009 | Canon imageRUNNER 2200
Admin password for Canon ir2270 MFC
Mar 17, 2009 | Canon Office Equipment & Supplies
Dept number and Password
You can turn off department id codes from the additional functions menu but you will need to know the system manager id code to perform this. If you cannot obtain the system mgr ID code from the people you purchased it from it will require a reset done in service mode.
I might be able to help if you cannot obtain the System Manager ID code to get into the admin settings.
Hope this gets you in the right direction
Feb 25, 2009 | Canon imageRUNNER 210S Copier
Detailed reports of when copies were made
Is this what u want ?????
To Print out the Department ID Print totals:
1. Select Additional Functions on the Control Panel.
2. Select System Settings.
3. Department ID Management.
4. Select On
5. Select Print Totals Page Totals.
6. Print List.
Feb 10, 2009 | Canon ImageRunner 2220I Copier
Hello, our department has a Sharp AR-550U. The option for Stapling (using it a a netword printer) is greyed out when trying to print. I have provided all users with manage document permission. The stapling...
go into the printer properties, if you are using a print server then this must be done on the server, not the workstations, go to the "configuration" tab and tell the driver what options you have installed then clickk apply.
Dec 31, 2008 | Office Equipment & Supplies
Payroll system in DBMS. I don't know what data is to be taken.
Firstly you need to determine/state whether you are using a database application, such as Access, MtSQL or MS SQL and programming them to do create this application, or are you using a programming development tool such as Visual Studio, ASP.NET, PHP or the like, as the solution and guidance will be different for each.
In terms of the data design, you should store the data necessary to identify each employee uniquely and each data point per employee needed to calculate their payroll. You should then store the generic (applys to all employees) such as tax rates, in separate tables and call on it to calculate wages and other paystub data.
For instance, the employee first and last names and tax ID should be a sufficient unique identifier. Create a table for just employees, their names, tax ID, start date, schedule, pay rate, number of deductions, direct bank payment data, etc., and whatever else you decide you need for each employee. You can calculate their wages by multiplying their rate by their schedule and applying the appropriate tax rate and medical/witholding deductions as you go, so calculated data does not need to be stored and consume database space.
You'll likely need a separate table for common data such as tax rates, one for deductions/witholdings, one for holidays, one for vacation accrual rates, one for medical rates, etc. This data if common to employees does not need to be stored per individual, as that would cause redundant replication of data. If the employees are on an hourly rate, rather than a set salary/wage, then you'll need a table of worked hours per employee, akin to their timesheet data. If you use a timesheet/timecard, the entering and storing only the totals and keeping the physical timesheet for backup records should suffice.
Once you design and populate your database as suggested above, then it's a relatively-simple task of calculating the computed paystub data and storing the salient resulting datapoints for the record.
Consider a reporting application, such as Crystal Reports, for your printing needs, as its far easier to configure Crystal or similar product to format reports, paystubs, checks, etc., than coding these from scratch.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Printing secure documents
I, could you give me your e-mail adress so i can send you the user manuel for security....
Make sure ti that you have a hard disk in your copier ???
Thank you!
Mar 27, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
211 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
