Question about Poulan Garden
Looking for a manual for a poulan micro super xxv
    President:
  • 2,220 Answers
Poulan.com
The dash number of your serial number is the type.
http://www.poulanpro.com/node4033.aspx or phone them
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 (Please have your saw within easy reach)
They should also provide a link to the correct IPL and Operator’s Manual for your saw. HTH
Lou
Posted on Nov 15, 2009
Testimonial: "thanks a lot Ted NorthBay Ont"
SOURCE: poulan micro xxv wich will run for 5 mins then flood but why?
clean out the vents on your fuel cap. you may also have sawdust or dirt stuck on the diaphragm in the carburator
Posted on Feb 25, 2009
dontbother10
  • 2220 Answers
SOURCE: Looking for a workshop manual for a poulan micro xxv deluxe
This is Poulan.com "POULAN-WEED-EATER" and your model number"Micro xxv"
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=MICRO XXV Gas Saw&AFID=59
HTH
Lou
Posted on Sep 05, 2009
  • 110 Answers
SOURCE: i have poulan micro xxv chain not being oil when
wow thats an oldie, That saw uses a diaphragm pump located just above and in front of the clutch drum. Its going tobe hard to find one if its bad, Try cleaning out the oiler hole in the bar first, Then try running the saw without the bar and chain on and see if it pumps.Also check the oil pickup tube in the tank, It has a small screen on the end of it thats prone to sawdust clogging it. If it still does not oil then I suggest you locate the gasket and diaphragm for the pump before you take it apart. Remember to clean everything before reassembling,, Good luck
Posted on Dec 19, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Micro Super XXV Deluxe S250?
Just like the video:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/PWE/MICRO-XXV-Gas-Saw/75.MICRO-XXV-Gas-Saw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 26, 2010
  • 2239 Answers
SOURCE: I'd like to know what steps to take to replace the
Its a long time since i saw one of these, however, start by removing the starter cover screws and the starter itself, you need to remove the flywheel nut,1/2 spanner as far as i remember, strike the non magnet side of the flywheel with a suitable hammer, the flywheel should just pop off, remove the points back plate cover, this should just pull off, the points and condensor are all one peice, held with two screws, either clean the points or replace the assembly, the back plate will have slots to allow you to set the points gap, the gap is between 12 and 15 thousands of an inch, put a small amount of grease on the felt pad against the cam, refit the flywheel and nut, take care to re fit it onto the woodruff key properly, the air gap between the coil and the flywheel should be set at approx 0.5mm, re fit the starter and check for a spark.
Posted on Apr 02, 2011
Trying to find a service manual for this. can you assist? thanks
Hi Linda:
Here's a link that will get a lot of sites where you may be able to get the manual. Just click on it.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Poulan+Micro+Xxv+Vintage+Chainsaw+service+manual
Hope this helps.
Keep those old machines running!
Cheers
Apr 02, 2016 | Poulan Micro Xxv Vintage Chainsaw Coil...
How does the oiler work on a poulan micro xxv
The oiler operates off the crankshaft under a cover behind the sprocket. Find the oil port near the back end of the guide bar where the oil pump injects the oil onto the chain. That port could be plugged. Your little Micro probably does not have an adjustable oiler but just in case invert the saw body and see if there is a + and - in the casting just under the sprocket. If so, moving the slotted adjustment towards the + increases oil flow.
Sometimes sawdust enters the tank when being filled and plugs up the inlet to the oil pump. Keep an old 1" paintbrush with your oil can so you can brush away the debris before opening the oil tank to fill while in the woods.
Sep 23, 2014 | Poulan Micro Xxv Vintage Chainsaw Coil...
We need a manual to help replace the fuel line on a Poulan Deluxe Super 25
You do not need a manual; exactly like the video that follows:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
No primer or second carburetor connection. Be kind to the oil pump; they are no longer available.
All fuel components are on the "Ignition, Electrical & Flywheel" print here (filter and hose are available):
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Lou
Apr 26, 2010 | Garden
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Looking for a workshop manual for a poulan micro xxv deluxe Thank you
HTH
Lou
Aug 04, 2009 | Garden
Poulan micro xxv wich will run for 5 mins then flood but why?
Feb 25, 2009 | Poulan Garden
Garden Logo
729 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
