Question about Hoover F6020-900 SteamVac Upright Vacuum
No suction When I turn the vac on it sounds ok but there is no suction and the brushes don't turn. Alot of air does come out of the two exhaust vents and the brushes will turn manually.
  • 2,427 Answers
Hey, how are you ?
here are a ew things that could be causing you sorrow
1.) Check your vacume to ensure that it isnt clogged anywhere
2.) before your compressor and after the filer, this part is where the suction takes place, check to see that it isnt clogged or that it isnt broken...
3.) check your packing (diapharam) in the vacume oto see if it ruptured(has a hole or broken)
4.) Check for lears on the vacume, basically run a pice of paper all over it and see if it is pulled to the vacume.
Once air is coming out the back, it means the compressor is working, but it alos means that the vacume is clogged, or a compartment that is u\supposed to be sealed is broken, or it has a leak somewhere..
My bet is that it is clogged somewhere, take it apart you will find it..
Posted on Jan 09, 2008
My rigid shop vac 4.0 has no suction
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Aug 01, 2018 | Shop Vac Vacuums
Vac has suction but no air exhaust
If it has suction it has to be exhausting the air. Filters should be replaced at least once a year.
Jun 13, 2014 | Riccar Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Loss of suction power & exhaust coming out of vents beneath exhaust port w/ barely/if any air pressure out of port itsef.
You should find your user manual, look up the phone number for Shop Vac's customer service and call them. They will be very helpful and with the unit being no older than that, it should still be in warranty. They will probably have you send it back and will possibly just send you a whole new unit.
Nov 11, 2013 | Shop Vac Shop-Vac 905-65-00 1-1/4" by 8...
Beater brush is good, vacuum running no suction
this sounds like your vacs dust passage from the rotary brush to bag is blocked ? you can diy this if you turn vac over to show the brush and covering cover you will see cover is held by some screw/bolts ? remove these and cover then the brush assy is slotted in place either side on bush/bearings and the drive belt is around the brush memorise how it fits! then gently/carefully lift brush out the belt will create spring action once brush removed you will see where the dust travels thro an arpeture on the belt side of vac this usually is where blockage is clear it out and any other within the area of brush then reassemble and check vac
Dec 08, 2009 | Electrolux Vacuums
No suction but good exhaust flow
This sounds like you have a loose pipe connection somewhere in your system. Physically check all connections. If you can't find anything suspicious, call a vac repair man that specialies in central vac repair. Joe
Aug 10, 2009 | Electrolux Centralux Vacuum
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Not cleaning as good as it used to
This vac. has alot of removeable covers, make sure that none has a clog and also that they are reinstalled correctly leaving no gaps. Does air blow thru the filter? Even after cleaning, if air can't pass thru, then they will restrict suction. Also is the brush roll turning, if not, then it would seem like there is not enough suction.
Jan 14, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover F6020-900 SteamVac Upright Vacuum Logo
110 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
