Question about ASUS K8V-MX Motherboard
I am adding new 160 GB Sata HDD to my System and reformat new Hard disk but the time of installation hard disk not found. But check bios. they have already detected
  • 3 Answers
I have had the same problem. The problem is that you need to load the raid driver / controller when installing the OS. When you are installing the O/S like in the first 60 seconds of the install you hit F6. You must go to asus and download the raid or controller driver. That should take care of your issue. I think moving the hard drive to another channel on the motherboard might be an easier fix.
Posted on Nov 15, 2009
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
150gb sata formated hdd not recongized by lenovo 3000 n200
ok..let's do one thing at a time...can you boot to F2, and see what your bios states is the case?
May 25, 2008 | Lenovo 160GB FDE 5400rpm SATA for ThinkPad...
My Toshiba mk4058gsx HDD is not detecting
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 20, 2011 | Toshiba (MK4058GSX) 400 GB SATA Hard Drive
Sir my inspiron laptop b130, intel pentium processor 1.70 mhz 598 mhz, it is suitable for upgration r not? ram 1gb. 40 gb hard disk.? I need 2 gb ram and 500gb usb hard disk for oracle applications...
Max RAM for that system is 2GB
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20B130&Cat=RAM
The question is whether there are 500GB hdds for that system. The largest PATA HDD I found was 320 GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4600076&CatId=2675
and there is no guarantee the BIOS will recognise a HDD that large as PATA HDDs require BIOS support for the drive size where SATA HDDs will pretty much work.
My recommendation is to retire this system and BUY a new one.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=631874&csid=_23
Sep 10, 2011 | Dell Inspiron B130 Notebook
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Hdd is not getting detected it is new hard disk the hdd is 160 Gb,cables are good solution to be not to open hard disk
u have installed the hdd properly
but not the bios..
open biios
press <del> or the key suggested by the computer when the computer boots.
u will enter bios...
now go to boot section
make first boot as the hdd shown in the list....
save the settings and reboot.
if it fails ..
unplug ur hdd. a and plug it again...
and follow the instruction again
Mar 11, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS K8V-MX Motherboard Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
