Question about Canon Office Equipment & Supplies
Canon irc 2620n with e000020/01.b0 - Canon Office Equipment & Supplies
  • 78 Answers
Yellow drum needs replaced
Posted on Dec 27, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
CANON IRC 4580, BLACK IMAGES COMES DOUBLE IMAGES
could be the secondary transfer roller is worn
Sep 10, 2013 | Canon irc5185i
Hi Tech support, I am getting the error code number E 000732-0001 on my LC3170i Canon printer
I am getting the error code number E 000732-0001 on my IRC 2620N Canon printer
Oct 13, 2010 | Office Equipment & Supplies
Canon irc 2100 showing the coad # E020-02A0
The Magenta drum unit needs to be replaced. Good day
Nov 06, 2009 | Canon Office Equipment & Supplies
I have a problem with my cannon irc 2620n , just show me this error code E220, i guees is same happen with scan lamp , but i wonna know , wat willi mean , en how can i kan fix up, pleas help me i willi...
Does your "lamp" is turned on when you open the cover? If not it could be that you have bad lamp controller pcb.
Try to manually pull the lamp on right side, and then turn on the copier, if lamp assy is moved in left position withaut error, that means that position sensor is OK, and you need to focuse yourself on "lamp"/ LED
Sep 29, 2009 | Canon IMAGERUNNER 2230 Copier
Printing C4 Envelopes on a CANON 2620N
try to use this linkhttp://www.canon.com.sg/section/contactus/?enqtype=TechEnq&enq_detail=Copiers
Aug 09, 2009 | Canon imageRUNNER C3200 Copier
Error e014-0003 on canon irc 2105
check ther heter unit are the heter motor is ok
Jun 05, 2009 | Canon Office Equipment & Supplies
Error 000001-0004 ON MY IMAGE RUNNER 2620N,000001-0003 on3200n
ok that code has nothing to do with your drums that code is for a error in the fuser unit, you have to reset it in this order ADD FUNC key// then hold down the 2 & 8 keys at the same time / then ADD FUNC key again... screen should change to serv mode.... then in this order.touch copier/func/clear/err. ok turn off copier then back on... if code comes back you have a bad fuser unit swap it out clear the code again then try the new unit
Dec 22, 2008 | Canon Office Equipment & Supplies
Canon IRC 3220N
Press *, then press 2 and 8 at the same time ,then * again
Sep 01, 2008 | Canon imageRUNNER C6800 Copier
132 people viewed this question
old marine
old marine
