Question about Dewalt 18 Volt Compact Drill Kit
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
  • dreamers1233 Nov 15, 2009
    hi no mate charger lights working fine
I have had and still do own these drills. The only thing that comes to mind is a faulty trigger. Try the battery in another tool or drill.
Posted on Nov 24, 2009
  • 187 Answers
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Posted on Nov 15, 2009
  • wire12me Nov 17, 2009
    Hi, sorry it took me so long to respond, but I didn't see your comment until now. My bad, I'm new. The battery is probably dead. Batteries last longer when they are frequently used and recharged. To be really sure about your battery, check the metal parts that engage when the battery is put into the drill and the charger. If you have a tester, your can also check the prongs from the battery to see if they emit a charge. They shouldn't be bent or blocked in either the battery or the drill. Again, sorry about my delay.
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Hi. I bought a Makita cordless drill, model 8391D. Whilst drilling a pilot masonry hole it suddenly stopped. The battery had only just started to slow so I changed it anyway to a fully charged one and the...
I would try changing the brushes and use compressed air I would blow out all the dust and lint I could from around motor.
If this does not help I would return for guarntee replacement. Thank you.
Mar 19, 2011 | Makita Garden
I have a Nextec 12V cordless drill, when i press the trigger, the light flashes, but, the drill does not work. i have tried different batteries and have changed the settings and switches and it still...
At first it does sound like the batteries.
How old is the drill? If it's old, then the batteries may either be dead, or need a careful, slow charge overnight to charge them properly. If new, then they may also need a really nice slow charge.
Sorry to ask, but have you fully charged all the batteries you have tried? !!! Many rechargeables lose a great portion of their charge if they sit for a long time.
Also, when using the drill, never use it until it runs the battery down so far stops, as this can damage batteries or discharge them to where again you need to very carefully charge them to get full charge back again.
Have you overloaded the drill:any plastic smells or have you drilled too hard and stalled it for a long time? That could cause motor damage. But look to the batteries first.
Feb 21, 2011 | Craftsman Drills
Hi I Have a Hilti TE 6A Old type recently bought new charger and battery is taking a charge and seems to be holding the charge but when i use the drill it keeps stopping but when i pull the trigger in...
I do not have any experience with this particular drill but I have a old drill and belt sander of my dad's that stopped working and since I was going to throw them away I decided to take them a part and took the switches apart and cleaned the contacts and now they are working just fine. JR
Oct 12, 2010 | Hilti Drills
My new drill suddenly stopped working even though the battery has been charged OK.
Is it Nano li-ion? have you got another spare battery to double- check?
I experienced the same problem with 18V Dewalt nano li-ion battery. Was fully charged, came to work- Dead!!! I was lucky I had spare one, so then i was ok, but anyways had to buy a new one. Check on these things:
1. Battery is faulty. If u have any chances to ask someone who has the same gun (voltage is very important!!! has to be the same!!!- 12V battery to 12V gun, 14.4 to 14.4, 18 to 18 etc). Put your battery into that other gun. If You find the same problem that means your battery is dead.
2.Gun with battery contacts. If you 100% sure, that batterIES (check 2 batteries, or more) are OK, check bottom contacts where u put battery in, use WD40, or similar to clean them.
3. Least common Dewalt thing (Most common in Panasonic drills) is trigger contacts.
Basically i do not know what model is your dewalt, i was only talking in general, but there are no miracles- stopped working suddenly, and what u describe new, for instance my new drill dw727kd is less than 1 year old, i was too stuppid to open that battery myself to void warranty :(
AAAAHHH!!!!!! One more thing - If you have not tried to open these screws- check your nearest Dewalt authorised repair center- new NANO batteries have 2year warranty!
Apr 24, 2010 | Dewalt 18 Volt Compact Drill Kit
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Dec 05, 2009 | Milwaukee 2610-20 18V Cordless M18 High...
Makita 6337D cordless drill problem
It is possible that the batteries are no longer good. They may need to be changed. These batteries do reach a stage where they no longer hold charge.
On rare occasions I have seen the gear box jam or the motor bearings go defective.
Jerry G.
Apr 01, 2008 | Kitchen Appliances - Others
Dewalt 18 Volt Compact Drill Kit Logo
464 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
