Question about Stainless Cruise 49 Marine Refridgerator - Measures 20 " H x 15 " W x 18 " D. - Steel model - CR0...
Fridge freezing hi there , have fridge freezer approx 12- 14 years old, fridge is freezing just like the freezer does , have already replaced the thermostate. twice just in case, compressor is running all the time, could it be low on gas......
  • mr zipper Jan 09, 2008
    thanks hotuna, sounds about bang on, compessor and piping hot am not at place at moment, did have afeel of it comp real hot and piping quite warm, earlier on, not a auto defrost,, items in fridge actually freezing solid,,, which doesn,t make sense when u think of low freon gas,,,,, would still not the stat cut the power to compressor when it was at correct temp,,?
  • darren Airey
    darren Airey May 29, 2008
    fridge is brand new but back of fridge is freezing up whats the problem
  • 288 Answers
Low freon charge will cause the compressor to run continuously, as it never reaches the set temperature. This will also cause excessive ice buildup as well. I am assuming this little fridge doesn't have an automatic defrost. If it does look at that next. You didn't say, but does it reach proper temperature? Go to the back where the compressor is. Feel the lines coming out of the compressor. the low pressure, or larger one, it may have insulation around it, should be cold. If you cant tell (sometimes these small compressors they look the same size) its the line leading inside the freezer. Feel about 1 foot away from the compressor, if possible. Next feel the high or small pipe, this one is going to the outside coil. This should be very warm, but not cool and not real hot. This goes for the compressor too. A 134A system sometimes is very hot when low on freon.
Posted on Jan 09, 2008
  • Rob Luna
    Rob Luna Jan 09, 2008
    Yes about the thermostat, it should shut it off. Place a separate thermometer inside, see what the temp is. It may be possible that the probe or sensor on the thermostat is incorrectly positioned. Or it maybe the wrong application. You may have a thermostat that shuts off at a much lower temperature than what you need. As for the freezing of items, low gas makes the coil acculumulate ice, not the food, sorry if I wasn't clear about this.
Fridge freezer is two years old. freezer is working but it is freezing up and the fridge is not working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Sep 13, 2011 | Frigidaire Refrigerators
How cold should my freezer be?
zero deg F. or -18deg C. for household Fridge freezer.
Deep freeze, like a chest freezer, - 10 deg. F. -23 deg. C.
Household freezer storage is good for approx 3 - 5 months depending on product.
Deep freeze storage is good for 2-3 years, again depending on product.
Jan 15, 2011 | Refrigerators
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
Had a repairman fill coolant (8oz) and now the
Too much refrigerant. Let some out until the frost back starts going away. Do it slowly.
Sep 08, 2009 | Refrigerators
Our hotpoint fridge freezer ffm74 has stoped working. The freezer doesnt work and the fridge is freezing everything.
hi the fridge requires cold air from the freezer,the air cant get in there due to ice blockage,defrost appliance for min 36hrs and then once the appliance reaches approx -12o the fridge should start to go cold
Aug 03, 2009 | Refrigerators
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost free fridge
Check and set both temperature adjustments, one for freezer should be no more than 1/2 and the refrigerator also as a starting point.
May 05, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge freezing
Your fan in the fridge is proberally going bad,, check your fan
Jan 09, 2008 | Refrigerators
Stainless Cruise 49 Marine Refridgerator - Measures 20 " H x 15 " W x 18 " D. - Steel model - CR0... Logo
160 people viewed this question
Top Stainless Refrigerators Experts
Dan Webster
Dan Webster
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
