Question about Maytag Performa PAV3200
Model # PYG3200AWW my dryer was having a hard time starting and now won't start.
    Sergeant:
    Champion:
  • 289 Answers
To check for bad motor,open dryer door,hold in door switch and someone push in on start switch,at the sam time reach inside the dryer and turn drum clock wise,if it start's than you have a bad motor.
Posted on Nov 15, 2009
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Dryer won't start immediately after finishing one load. needs cool off time. and now, won't start at all! what should i do?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 24, 2011 | Dryers
I have a Maytag PYG3200AWW and it won't start.
Sounds like a problem with a limit control switch. Some are manual reset and some are automatic . Not sure about yours. They are located of course, in-line within the wiring harness limiting the amount of heat build-up within the machine. If yours had been running with a stopped up, or patially stopped up vent, (and your limit swithch IS AUTO reset,) then the switch could have been cycling the heat numerous times, over that period, preventing overtemperature conditions. This would weaken the switch because it is a safety device and not actually a cycling device. Also, in the vent exhaust, @ the back of the machine there may be a limit switch. And of course, it could always be the start button..........
Jul 27, 2009 | Maytag MGD6300T Gas Dryer
Washing Machines Logo
176 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
