Question about LG enV3 VX9200 Cell Phone
Starting last night, each time I press OK, it flashes. I double/triple checked the flash was set to OFF in both the picture-taking and video modes. Even flashes sometimes when I'm not even touching it and have phone just down on the table. Have you heard about this problem before. Last time I used the camera was last Friday. Thx.
Flash wont work
Use the flash when you take pictures at night, indoors, or outdoors in heavy shadows. You can chose what flash mode, by pressing several times on the little button on top of the camera where the lightening logo is. One of the settings is flash off. Make sure it is not in that mode, because even when it is dark the flash won't fire. The other modes are flash, fill in flash and red eye reduction flash.
Jan 20, 2014 | Kodak EasyShare M1073 IS Digital Camera
My pictures are blury and I am tired of it.
First make sure you're on Auto mode (press SCENE and choose AUTO mode)
Use permanent flash by pressing UP until the flash logo gets selected, then press OK.
Also, if you don't want to use the flash, put the flash on AUTO and press menu, go to "Set up", scroll to "Anti-shake AE" and set it to "Auto", press OK to save settings and try taking pictures again.
Nov 09, 2010 | Nikon COOLPIX L20 Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
Night problems
have you tried it with the led flash mode
Sep 23, 2008 | Bushnell 11-9900 Camcorder
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Black pictures
Check your settings - could be if very black night, and you set it to 100 iso film speed, and maybe you are on say 1/1000 of sec at maybe f16, then that's ok. You would maybe need an explosion in an oil refinery to capture much.
However, you perhaps could try this:
1 change the battery for fresh one, and see if it helps - sometimes, the shutter won't really shut if battery power is very low
2. change the mode setting to auto, and see if the flash pops up and takes a pix - then if the pix is good, the camera is still working
3. Reset the camera to the factory defaults, by:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
If that fails, back to Canon! - good luck
Apr 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Flash Settings Only Work When in Night Mode
Hope this helps it got mine working
leave lens cap on in night mode then start up flash & take a shot,
press the flash key symbol button & you should see changes on the screen monitor, then go to auto mode to take a shot with flash make sure AF is not on.
Sorry it is a bit vague but this got mine working again.
Dec 13, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
LG enV3 VX9200 Cell Phone Logo
46 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
