Question about Asrock K7S41GX SiS741GX Mainboard (MBASRK7S41GX) Motherboard
I have install a new mother board, but when i power the computer the power come on, but no response on the monitor
  • 4,281 Answers
Or reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Posted on Nov 15, 2009
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor.
HERMAN has the correct response. For the info you posted.
When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Aug 07, 2012 | Acer AL1917W LCD Monitor
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
Hi! My mother in law has a problem with her Asus MM19SE monitor and I sit on the phone with her. When she starts the computer (equipped with XP), she can see the logon. When she inserts her password and...
llindfors61, Hi, 12fixlouie here. This monitor must be past it's 3 year warranty period. You or qualified "cold-cathode-fluorescent-lamp back-lit lcd monitor technician will need to replace some electrolytic filter capacitors that may have failed on the internal "switch-mode-power-supply" printed circuit board. Retrevo . com lists this unit as "time to retire" If you repair power supply, unit may function for 2-3 more years, but will need new cold-cathode-fluorescent-lamps installed at some future date when screen "white's" start to turn "faint pink" in color. Lots of video clips at YOUTUBE about replacing capacitors. Write back to me by aoing additional comment an rate this response after doing your research. 12fixlouie
Sep 08, 2010 | ASUS MM19SE (Silver,Black) 19 inch LCD...
Intel 845 GL mother board no display ;processor memory & SMPS are working fine in another mother board
Does it have any beep sounds on switching on( some computers won't produce beep sound) or does your monitor is not getting any signals from computer even though it is ON and has shown any message or menu screen of Monitor functions then,
You will be having a faulty RAM or your Graphic port has some hardware malfunction.Or it can be also from a new unsupported hardware installation that will prevent computer from booting up.
If your monitor does not provide any of the above monitor functions successfully then
It would be a monitor problem. Check wires or cables of monitors or contact nearby technical support
Sep 06, 2010 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Self test screen on monitor; pc power on but no response from keyboard.
Friend!! please ensure that all the cables are fixed well or once again remove them and put them again. Change the CMOS battery with new CMOS Batter which is essential to run POST. Check the VGA Cable (Monitor's) to the mother board or video card!! Restart!! your problem will be solved!!!!
Feb 19, 2010 | Computers & Internet
Gateway 510X H Desktop will not power up
Yes, definitely. You need to change your power supply.
Jul 23, 2009 | Gateway 510 X (10272197) PC Desktop
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
Newly built computer starts up without using switch
No signal means, monitor has not been connected. (for crt s) and, on startup (for lcd s) . Easiest solution should be, PLEASE REMOVE AND PLACE THE RAM TIGHTLY AGAIN. i hope, it will solve the problem, if you have recently traveled with your cpu.
Apr 04, 2009 | Intel D915PGN Motherboard
Computer turns on, but there is no display on monitor.
my goodness.. you have spent a lot in your computer i think.. i dont think changing mother board and installing a new vedio card will solve this problem.
as u have said that u have installed a new card make sure that you are giving the connections of your monitor to the gforce card and not to the mother board again.
if connection for monitor is going for gforce properly your RAM is the problem. as per your configuration its single 512mb ram. i would advice you to go and get another DDR RAM(same 512 prefrably) from any of your friend and put it in you mother board in by removing the normal RAM you had.
this will work for sure i think.
if this is not working dont rate me in-approtiate. i just triend my best. sorry and tahnks.. good luck
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
