Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
My Black and Decker Grass Hog Trimmer has performed well. I have had it for 3-4 yrs. The last time I tried to use it, actuating the trigger nothing happens. Battery indicating charged by the Green indicator light, I have 13.65 volt D/C accross the battery contacts, The safety trigger is actuation correctly. It is just like no voltage is getting to the motor? I have rotated the head many times with no response. Just dead? Do you have any suggestions?
4 Suggested Answers
SOURCE: CST1000 Black & Decker Cordless Trimmer/Edge won't start
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CST2000_TYPE_1
Part number #243614-00.
It's a microswitch made by Honeywell that costs about 5 bucks plus shipping.
The attached file has the schematic and parts list.
The CST2000 is well worth spending a few bucks to keep it going. Finding a local B&D authorized service center near you will even save you the shipping as they can order it for you.
Every other component is pretty dependable- the motor, battery, wiring, charging system, spool system- all built to last.
Only down side is you really only get 20 to 25 minutes of hard weedwhacking before you need to recharge. Of course, it's time for a cold beer in the pool by then.
Posted on Apr 24, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
tomgswan
  • 30 Answers
SOURCE: Black and Decker electric trimmer (grass hog)
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Posted on Jul 02, 2011
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Jun 14, 2015 | Black & Decker Black and Decker & Grass...
Electric black and decker 14 grass hog won't start
spray the contact area on the weed trimmer with some contact cleaner WD 40 will work also
Mar 30, 2015 | Black & Decker Black and Decker & Grass...
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Apr 28, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
124 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
