Question about Samsung Gravity SGH-T459 Cell Phone
My sasmsung gravity's default texting setting is "ABC", How do I get it to be "T9" by default so I don't have to change it every time?
How can one type with a normal typing keyboard rather than hitting abc for a c?
If your phone only has the numeric pad you can change the setting from "abc" to "T9". T9 is a predictive texting mode, so if you wanted to type the word "hello" you would just press the corresponding numbers 1 time, for example: 4(gHi)-3(dEf)-5 (jkL)-5(jkL)-6(mnO), so you would only hit 4-3-5-5-6, if the word is not the first word displayed you can hit the next key which is usually either * or # depending on your phone. The T9 setting is usually changed by again hitting either the * or # key, or sometimes 0. It is also sometimes selected on the texting menu from within the message.
Learn how to use T9
Sep 06, 2011 | Cell Phones
I dont like t9 texting on my phone.... i turn it back to abc texting, but it keeps changing back to t9.... it getting aggravating to have to keep turning back on abc everytime i go to text sumeone...
1. From any text field, tap the arrow next to the input panel icon. Options... 2. Tap
Enter text tab, choose Input Method 3. From the an input method. 4. Tap .ok
Some of the input methods may not be supported according to the language.
You can also set options for some input methods
please rate this if useful it only takes 1 second!
Dec 20, 2010 | Samsung SGH-I200 Cell Phone
How do i get the t9 off my text messages on a samsung d900???
ABC, T9, Number, and Symbol modes
You can enter text in some features such as Messages,
Phonebook, or Calendar, using ABC mode, T9 mode,
Number mode, and Symbol mode.
Changing the text input mode
• Press the right soft key to change the text input
mode.
• Press and hold [ ] to switch to Number mode.
• Press and hold [ ] to switch to Symbol mode.
Using ABC mode
Press the appropriate key until the character you want
appears on the screen.
: ABC mode : T9 mode
: Number mode : Symbol mode
Apr 07, 2010 | Samsung SGH-D900 Cellular Phone
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Oct 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Changing defaults
1) When you type the text using the keypad(screen), press 'Abc' and select 'T9 Abc'. That will solve your first problem.
2) You cannot do that by default. Everytime you need to move the messages using the option 'Move to Phone'.
3) Unfortunately they have not given the direct option. First you need to move the message to phone using the option 'Move to Phone' and again do 'Move to folders' on the same message and choose the folder.
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Is there a way to change the text mode to abc permently
In most phones now if you go to settings and look for something involving your keypad or anything like that you can find a setting saying set default input it is most likely set as T9 but you should be able to switch it to abc and it should stay the same you might have to do some hunting for option depending on your phone.
Kyle
Jul 09, 2009 | Samsung Cell Phones
Cant set T9 as the default entry method on LG cu920
yes you can set T9 as default on the Vu just go to the new message touch options and touch text entry mode and touch T9 Abc and that will become your default
Dec 24, 2008 | LG Vu CU920 Cellular Phone
SEtup t9 texting
When in Text mode, press the # button. With each press, you will see the 'Abc' on the screen changing. When you see the 'Abc' with a small book by it, then you are in T9 texting mode.
Nov 10, 2008 | Motorola Mobility W375 Cellular Phone
Samsung Gravity SGH-T459 Cell Phone Logo
275 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
