Question about Sony Ericsson K750i Cellular Phone
I am trying to locate the schematic for a Motorola MC34018p IC
I need help locating the schematic for a MC34018P IC used in a Sony phone to use in making a project.
Would you refer me to a source?
  • Anonymous Apr 06, 2008
    Hi!
    I have the same trouble to finding datasheet for MC34018P.
    President:
  • 1,017 Answers
Where can blutooth ic be located in nokia e5
have you tried to download the schematics for this phone? try this link http://elektrotanya.com/?q=showresult
May 17, 2014 | Cell Phones
Sony ericsson EP800 USB+5V charger IC SO8 is burned and I can't detect the part number
Just get another on EBAY. It's not worth messing with versus expense. Ya, it probably could be fixed, but hard to find a schematic for it.
Dec 10, 2012 | Sony Ericsson EP800 Power-Saving...
K770i sim ic location in board
i want to know sonyericson sim ic location in board.pls show me now
Apr 05, 2012 | Sony Ericsson Cell Phones
Where is the power ic of motorola l6?
Released in 2005, Motorola has discontinued L6. But I am sure you can get a compatible power IC of other Motorola models. The power IC is located near the SIM tray.
Dec 04, 2011 | Motorola Mobility L6 Cellular Phone
Razor v 3 keypad will not light up,everything else is fine
Hi,keypad light issues for Motorola phones are usually caused by the flex of the phone and also the Keypad IC.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
also When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Hope it helps.
Thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
My phonekeypad stopped working all of sudden what should i solve the issue
Hi, Issues like this are related to the flex of the phone .The flex controls the function of the keys on the pad.
Also it might be the keypad IC of the phone. But in other to know if it's the keypad IC, you will need to take it to a repair shop to check that out for you.
You can get a replacement flex from any of the phone repair stores around you also.
Hope it helps.
May 22, 2011 | Motorola Mobility MOTORIZR Z3 Cellular...
Two extension number not working
Hi, what causes extension number not working is because the IC that controls the number is damaged and it will need to be replaced.
The IC is a tiny chip located on the board of the phone. To be able to locate where the IC is inside the phone , You will need to unscrew the phone and Locate it.
But it's a little bit more tiny and technical than you expect. You might need to consult a skill personnel for assistance to help you locate the particular IC that is damaged and help you replaced.
Thanks for using fixya........
Jan 05, 2011 | Cell Phones
I dropped my cell phone on the ground and now it's acting up! i can see the screen but then it turns all white and it freezes! how can i fix it?
This is a common problem which happens in most caes when you drop a mobile..
Al that would have happenned is the digital display IC would have moved from its position due to the vibration of the fall.
If you are technically handy working with the internal parts of the mbilt phone and if you have proper tools for the same you can open the mobile panel and locate the display IC and desolder it and try using the phone..
If you are a novice working with the circuit board please take help of a technician..
Dec 21, 2009 | Motorola Mobility RAZR V3
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
51PP9303H/17 convergence repair help
I would change all convergence IC not just the one that holds the red. You will need the schematic to get the resistors location.
May 01, 2008 | Televison & Video
Sony Ericsson K750i Cellular Phone Logo
81 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
