Question about Hotpoint Ultima WDM73 Front Load Washer / Dryer
My door will not open i have tried everything but it still will not open unfortunly have mislaid my book work for it but it comes up with "f 05" on the screen please advice
  • Hotpoint Master
  • 3,463 Answers
F05 means pressure/ water level switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter in side of hose.
This should solve the problem.
Please rate my solution.
TRhanks.
Posted on Nov 15, 2009
05 ford focus: continuously flashing open door light on my cluster.
the door sensor is bad replace it and you should be good
Sep 18, 2015 | Ford Cars & Trucks
2012 mini cooper s, w/ alarm and cimfort access. Alarm, comfort access, interior lighting not working. When I have pass side door open cat will lock, drivers side door open doors will not lock. Open rear...
Best thing go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Feb 27, 2018 | Mini Cars & Trucks
Keyless entry remote doesn't open doors anymore on my 05 ford focus
Sounds like the contacts in the buttons are not making contact.. you may want to try taking the remote apart and cleaning the contacts and seeing what happens. If the remote is truely dead you may need a new remote
Feb 01, 2015 | Ford Cars & Trucks
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Jun 07, 2012 | Spyder 03-05 Chevy Silverado Vertical...
F7 shows instead of door lock
This happens with a lot of ovens. It's because the mechanism that locks the door is stuck. When the door doesn't lock you can't do a self clean. They don't want you to be able to open the door while the oven is 800 degrees? or so. Look just below the little button that gets pushed in when the door is closed, upper left, and you should see a vertical slot. This is where a little lever comes out and grabs the slot on the door. There is a microswitch inside that tells the oven if the lever has come out or not. Your lever is stuck.
You can test this in a totally dangerous way by opening the door, holding in the button, and turning on the self cleaning. If everything is correct you will see the lever come out to grab and lock the door, but your's won't because it's stuck. Jiggle it or push on it or pull on it with needle nosed pliers. It frees up pretty easily. But when it does, the oven will go into self clean, which you don't want it to do with the door open, so turn it off, close the door and try again. It should work fine.
Dec 01, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I have mislaid my passport in my house and require the number urgently to book accommodation in Holland. Can I find the number without the passport?
Hmm. Can you travel to Holland without a passport?
If not, then you should NOT book anything.
Hire a "house-cleaning" service; these "maids" will come in, and, for a fee, clean your home, and probably will "find" your passport.
May 20, 2011 | Computers & Internet
2005 Dodge Durango Front AC won't blow cold, back air works great
could be the front door for the front air needs to be propped open so that is blows cold, could also be the a/c compressor or a clog somewhere up front in the vents... it could be numerous things, but i would say try propping the door open, if that doesn't work try replacing the compressor... haynes makes the repair manuals for the truck, goto auto zone, pep boys, etc. and pick up the book they have step by step instructions on how to fix the most common problems and all the different systems of the durango... the book will be very helpful, cause if you do your own work you can find everything easily..... hope this helps you...
May 16, 2009 | 2005 Dodge Durango
05 caravan passenger power sliding door will lock but not open
READ YOUR MANUAL. THERE IS A SEQUENCE INVOLVING REMOVING A FUSE WHICH RESETS THE ELECTRIC DOOR OPENER. IT IS DESCRIBED IN THE MANUAL. EASY TO DO ONE YOU HAVE THE BOOK IN HAND.
Apr 15, 2009 | 1997 Oldsmobile Silhouette
Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
