Question about Garmin Rino 530 GPS Receiver
My battery on my garmin 530hcx will not stay charged,will only get an 87% charge. then dies out within an hour or two.
4 Suggested Answers
SOURCE: No battery status Garmin 760
Need to "fully" charge on AC power to get the battery status to show. I usually charge it overnight.
Posted on Mar 08, 2009
  • 1514 Answers
SOURCE: garmin 765t can charge garmin with usb port,
It's most likely that the fuse in the plug of the charger lead has blown. There's a ring at the top of the charger plug. Unscrew this and the plug comes apart. You'll see the fuse inside. Be careful not to lose any parts.
Posted on Sep 27, 2010
SOURCE: Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Posted on Dec 10, 2010
Garmin 1490LMT will not charge/hold a charge in the car. I just replaced the battery, gave it a full charge in the house on a USB wall charger and then it dies after about 2 hours in the car. I just...
Make sure the battery contacts inside the Garmine are clean. Use an eraser to clean the contacts. if this does not help then you might have a problem with the charging part inside teh Garmin itself.
Sep 13, 2013 | GPS
My Garmin Nuvi 780 will not stay charged. also i am unable to charge it while I drive.
The Nuvi 780 is an older GPS. Most likely, the battery needs to be replaced due to age. Many lithium-Ion batteries are only good for 2 years. More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
Please have the battery replaced by a professional. We have repaired many units from failed battery replacements by customers. Often other things get broken in the process, sometimes beyond repair.
Apr 09, 2013 | Garmin nuvi 780 GPS
Have 97 acura won't stay charge changed battery
the battery wont stay charged? if youre putting in a fully charged battery and your car runs, but then the battery slowly dies, the problem will be your alternator. the alternator is what maintains a car batteries charge. try replacing the alternator. hope this helps.
Aug 15, 2011 | 1997 Acura Integra Type R
1987 Toyota Pickup 4x4 Problems I have a 87 Toyota that has been giving me problems for a while now. I just got a brand new Die Hard Battery w/ 650cca because old battery was done. After putting it in I...
hello, it sounds like the alternator is the problem, most auto parts stores can check the alternator/charging system at no charge without removing it from the truck, I'm sure you will find that the alternator needs to be replaced.
Apr 02, 2017 | Toyota Xtracab Cars & Trucks
Need to locate the voltage regulator 87 chrysler lebaron battery will not stay charged
im am dealing with the smae thing i got an 87 lebbaron and i got to jump my car every morning cuz the battery dies over night but my friend who knows alot about car told me that the voltage regulator was built into the alternator that year so u have to replace the alternator or something im not sure but this guy does know alot about cars and if u find out let me know cuz like i said my car is doing the same thing
Nov 04, 2010 | 1987 Chrysler LeBaron
I battery went dead. I have pluged it into my computer . It lights up and shows a picture of it attached to the computer and the word Garmin but it does not show it chargeing.
Please leave it to charge and after about 2 hours - check it.
The Garmins need an initial charge to run - it is not bypassed if dead. It will not run on adapter power.
If it will not charge in vehicle or home - the jack may be loose from the board - but more likely the battery has failed.
Garmin DOES repair for a flat fee - units that are OUT OF 1 year WARRNATY CLICK HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Garmin nuvi 265 Car GPS Receiver
Our Garmin Street Pilot will not charge. Do the
The batteries DO die after a time. They are not designed to be replaced by the user. If you believe your battery has died, you should contact Garmin.
Jan 05, 2010 | Garmin StreetPilot C330 GPS Receiver
Can not charge only works plugged in
Your Garmin nuvi 5000 will never charge because it has NO internal battery. The only time it will operate is when it is plugged into a 12 volt power source. I have one and it really doesn't bother me at all. I bought a second cradle and a 12 volt adapter for use in the home.
May 19, 2009 | Garmin Nuvi 5000 GPS Receiver
Garmin nuvi 765 lithium battery will not hold a charge more than 15 minutes!
This is kind of a late response, but this post may help other people. I had the same issue and was ready to have Garmin exchange my battery until I called them today and spoke to Tech support. They helped me upgrade the firmware on the unit (didnt take long) and so far the problem has been resolved. I have had it on for two hours without fully charging it, which is better than before when it only stayed on for about 20 minutes. I recommend that people with this issue call them first since it appears to be a common issue with this model nuvi.
Mar 27, 2009 | Garmin BATTERY PACK, LITHIUM-ION, DC 20
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Rino 530 GPS Receiver Logo
143 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
