Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
I have a troy built pressure washer leaking gas from the air filter i looked around for advice and hurd bang against the carb and it will realease the float valve i did it and it worked but should i clean out the fuel in the filter area or the filter will it harm it as it is or should it be okay? the filter was soaked in gas dry now and when it happened the gas flowed from the air intake (behind the filter) if i need to clean out in there how do it do it and if i need a new filter do you think lowes would just ... have one ? thanks
    Scholar:
  • 110 Answers
Definetly replace the paper filter and yes Lowes will carry them.if it does not leak now, I would leave it alone or you will be installing a nine dollar kit.The briggs kit # is 294260 is you choose to do it anyway
Posted on Nov 17, 2009
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt pressure washer air filter is flooding with gas
rebuild the carb and check the mounting seals between the carb, air filter and engine. It's probably just gummed up & it's not stopping the gas from free flowing into your airbox.
Nov 09, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
Jul 01, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Have a troy built pressure washer and the gas is leaking out help
the float is stuck you can either take it apart and clean it or you might get by by just tapping lightly on the fuel bowl on the bottom of the carburator to unstick the float
Jun 20, 2009 | Garden
Troy Built Pressure Washer 6.75HP Motor Leaks Gas from Carb
Sounds like moisture sitting in your carburetor bowl, while in storage, has caused some corrosion which is preventing the needle valve from closing. Drain your fuel tank and remove the small bowl at the bottom of your carb. Carefully clean the needle valve and seat with a soft cloth. Test the float to make sure there is no liquid inside of it and that it actually does float when suspended. Take care to reassemble the needle valve and float and bowl the way you removed them.
May 22, 2009 | Troy Garden
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
1,062 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
