Question about Bugaboo Frog Stroller
My son put the small wheels in backwards. is
My son put the small wheels in backwards. is there any way to remove them now?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Yes you can remove the wheel by pressing very hard at the top of the wheel or by using a screw drive to push it in. it's not easy but it can be done. or go to www.buggypitstop.co.uk they repair and service bugaboos
Posted on Dec 05, 2009
Micheal, the cylinder head does have the mark on that wheel which holds the timing belt. But I want to know which side of the must it point?
It has a mark. A small dot, small triangle or a line. They are indented in the gear. Oil sludge will cover them. But is is there. With out it, no one could put correct timing on the engine. No year make or model either. If you remove the gear, make sure it isn't on backwards.
Oct 05, 2016 | Cars & Trucks
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
My son hockey bag starp is stuck under the spin wheel. how do i remove the spin wheel ^
There is a small cross-headed (phillips) screw in the centre of the shaft which holds a small round steel washer with a tab on it. Remove the screw and slide the tab off the shaft, taking care to note its position. Then you can wind off the pulley by spinning it anti-clockwise.
Jul 23, 2011 | Maytag Washing Machines
How do you disconnect the rear wheel on a 1990 CBR 600
as in remove?if removal easyest way put on centre stand slacken chain adjuster nuts,then slacken wheel spindel,push wheel backwards so chain becomes real loose....undo wheel spindel fully tap wheel spindel out wheel should slide out
Apr 16, 2011 | 1990 Honda CBR 600 F(1)L
D60 error press shutter release button
Here's what I found on the Nikon forum and it also works for D60 Digital Camera.
Get a very small cross head screwdriver (watchmaker size)
A can of WD40
Sticky tape
A good light
Remove the Battery and SD card
Open up the bottom of the D40x putting the small screws onto the sticky tape in order of removal.
You know the camera well, so you know where all the screws go.
Remove the metal plate (used for the tripod mount, you will need to remove the back of the D40x as well, it's only 2 screws)
Now look at John C Ayr's pic of the D40xwww.flickr.com/photos/johncayr/3969534234/
Spray a SMALL amount of WD40 onto the red and white gear wheels.
(Don't use so much that it drips down onto the optics, you don't want oil in there!!!)
Put the battery in and hold it down to make contact, put in the sd card and switch on the camera and try the shutter button. (switch it to manual focus or it might try hunting around for ages for focus)
It might start working, if not move the red wheel a few stops and try again.
Once it's lubed up and the wheels move it should be ok.
Keep taking pics until you feel it is ok.
Then reassemble following the screws backwards on the sticky tape.
Mar 23, 2011 | Nikon D60 Digital Camera with 18-55mm lens
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Installed new front pads and brakes grind when applied what did i do wrong
I would pull the wheels again and take a look to make sure I didn't mistakenly put one of the pads on backwards, with the metal backing plate facing the rotor. I pulled this stunt about a month ago and my son caught me, talk about a red face. Hope this helps.
Sep 30, 2009 | 1996 Chevrolet Blazer
My son's Daewoo Lanos has two stripped lug bolts on one
you can get replacement bolts and nuts at any auto parts store. just tell them what kind of car it is, and theyll match you up with the right ones. be sure to replace the studs and the nuts. theyre fairly inexpensive. to replace them, you remove thebrake drum or rotor, and simply use a hammer to pound them out backwards. or, they may be mounted on the cars spindle, rather then the rotor or drum. after you have them out, slip the new one into the hole. they must be pressed in, so its not gonna go in all the way. the easiest way to do it is to set it in the hole, put the nut on the threaded end, and just tighten up the nut. that will pull the stud all the way through the hole. then simply reinstall anything you removed from the car, and make sure there is a good amount of torque used to tighten the wheel down.
Aug 09, 2009 | Daewoo Lanos Cars & Trucks
89 4x4 pu broken wheel stud
Half right...pound out, use a stack of washers and put nut on backwards and draw stud in. Oil on washers and stud threads helps.
Jun 19, 2009 | 1989 Toyota Pickup SR5
Remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Feb 17, 2009 | Kenmore 63942 Dryer
Bugaboo Frog Stroller Logo
248 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
