Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
When my screen is blank, bars can be seen across the screen, and when viewing, a green tint appears on most white objects, is this the Light Engine going bad?
  • RCA Master
  • 5,138 Answers
Its a good possiablity that the Light engine is the problem, first Ck over on power supply Board if you do not see any Bad capacitors sometimes this will throw you and can cause problems in video. Chances are it is the Light engine Encompass Parts Distr. Lists your TV But has HDLP61W151yx or 2 yx or 3 yx or yx4 Go by the model number that is yours it will be on back of TV then once you know which one it is Go to Encompass online or Call 1-800-638-3328 find out correct Light Engine number They list the yx1 Part# as 263223 this one List for $769.00. OK heres another company that sometimes Gives return DUD FEE for your old Light Engine and it makes it cheaper UED Call 1-800-648-6657 and Try E-Bay under Electronics I have seen some good deals on Light Engines thier with Good warranty as well.
Posted on Nov 18, 2009
Testimonial: "I have returned to the vendor the Light Engine for repair."
Picture stays on for about 4 minutes ... then 4 color bars appear across the screen ...Red, green, blue, white ???
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 23, 2017 | Televison & Video
Mitsubishi 62" DLP WD-62525 has no picture no menu only green vertical bars
can you see any of the on screen displays like menu or volume?
I've seen a problem with this model that only had white vertical bars and had to replace the light engine.
Mar 14, 2014 | Mitsubishi Televison & Video
I thin k I am having back ilight and/or inverter program with my HP dv6275us Notebook based on the following: - machine powers on but o video or image on screen or image is extremely faint. Upon closer...
These are typical symptoms of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
As for the cost, I would suggest a search on ebay.com
Sep 06, 2010 | HP Pavilion dv6275us (RP284UA#ABA) PC...
After a half hour of operation, the picture begins to shadow.
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 50UX57B 50" Rear Projection...
THEN SEEN HAS A LITE GREEN TINT TO THE BOTTOM PART
Sounds like your main control board or the color wheel.
Dec 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Green tint to sony kds-a2020
NOT ON THIS SET YOUR LIGHT ENGINE IS DEFECTIVE CALL sONY AND SEE IF IT IS ON THE EXTENDED WARRANTY LIST.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
White bar coming across my k800i's screen.
try changing the current theme of your phone and check if the white bar will still appear...
May 03, 2008 | Sony Ericsson K800i Cellular Phone
LCD show purple or violet cast on white areas when using auto mode
Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
Dec 31, 2007 | Nikon D40x Digital Camera
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
471 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
