Question about Gaggia Titanium Espresso Machine
The ventilate button is not working. the machiine needs to be ventilated but when i push the ventilate button nothing happens. Is there a way to reset the machine. I have turned off, unplugged and turned back a few times.
  • Ernest R
    Ernest R May 11, 2010
    Do you push the hot water button then open the knob?
  • bansheracer May 11, 2010
    HI Do you hear the pump? Do you have any other messages or lights?
  • Gaggia Expert
  • 109 Answers
There is no ventilate button.
You will need to open the steam valve on the side of the unit.
Ensure your milk frother is not blocked.
Posted on Feb 22, 2010
  • dotti7 Mar 07, 2011
    I did press the hot water button, the wand is not blocked, and the steam valve was opened. When the valve is opened it makes a little start up noise and then no noise. I have run a descaler cycle (with plain water) just to see if it would run through. It did. But now no water comes through, or it does in little bits then stops to a drip and nothing; I thought it might be a pump problem. Any solutions to pump problems?? Thanks
  • Ernest R
    Ernest R Mar 07, 2011
    Try this push in on steam knob, if that works then the assembly for the steam valve needs to be replaced or the tap rod. Ask for the stainless steel steam valve assembly if you are going to replace the whole thing.
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
It says 'ventilate' and nothing works. I have tried to turn it off and back on but it doesn't work.
Hi
Like the Royal Pro machine and Royal Coffee, there is a water button on the Comfort that you need to press to run water. If when you press it and nothing happens you have a stuck solenoid, probably from scale build up. See what happens when you push the button with the drop of water or it may have many drops depending.
Dec 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
Hello I have a problem with y machine. I have got a message "Ventilate", and i have pushed the button 26, but nothing happens. What to do?
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 04, 2010 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Ventilate sign is showing and nothing works
Open the steam valve when the hot water words appear above the ventilate
Jul 21, 2009 | Saeco Royal Professional Espresso Machine
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
I have a brand new acer aspire one. A moment ago, when I wanted to open it, I saw that the green light on its top right, that is, at its "start" button was on, and the battery was a bit displaced at one...
Most likely your laptop is going into sleep mode. Lots of them do not like sleep mode if nothing happens when you push the power button try to hold it down for about 5 sec. your computer should power off and then you can start as normal. If this problem persists change the options in your control panel to turn sleep mode off. That should solve it.
Dec 18, 2008 | Computers & Internet
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
367 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
