I have finger marks on the screen how do i get them off. it is a samsung digital television with projector screen (plastic screen)
  • 557 Answers
Go to Staples or Office depot and buy cleanner for an LCD screen. Comes with optical cleanner and a microfiber cloth.
Posted on Nov 15, 2009
How do I fix magic focus error 5 on the one green projector screen. all the other projectors blue and red are fine
Hello, the convergence i.c.'s have failed. you will need to change both i.c.'s and check the tan colored fuses by them they will be marked on the board with an E*** and a 3 digit number (example: E401). They are solid tan about 3/8 inch long 2 amp chemical fuse or pico fuse. ...tks
Jan 12, 2015 | Hitachi Televison & Video
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
My NEC projector MT1065 display colors okie, but with black (or dark) image, the screen display a greenish wash in the center of screen. This happen just the same with new lamp. It appears as if the...
It sounds like the polarizer filters are starting to ware due to heat build up, if you remove the lid and the main booard, there is a white plastic mesh cover over the lcd panels, you can remove this and adjust the polarizers for the red, green and blue lcds to adjust the black level, there are 3 hex bolts holding a plastic frames which in turn hold the pre polarizer filters, buy slightly loosening the bolt you can slide the plastic frames left or right to adjust the levels, buy you should mark the position before you start. this may not solve the problem but may help to improve it, unfortunately these projectors require special software to make electrical adjustments which is hard to get hold of.
Aug 17, 2011 | NEC MultiSync MT1065 Multimedia Projector
I just finished replacing the color wheel on my samsung dlp tv and now there is a 3 inch wide dark stripe down the left edge of the tv. the stripe is transparent but it looks like something is covering up...
First thing you want to check is the bulb alignment and make sure there is nothing obstructing the light source. Check the foam sheath on the projector lens and I hope you didn't touch the color wheel with your fingers, you coauld be seeing the effects of finger prints.
Jun 08, 2011 | Televison & Video
The picture is slitly green tinted on the screen ?
Apr 29, 2011 | NEC MultiSync MT1065 Multimedia Projector
How to change coolant? im guessing the small plastic bag is the resivoir? and it is empty
the coolant, atleast the type for the color projectors, is in the color projectors which its generally near the screen on two metal holders. for further information go to www.TvRepairKits.com
Feb 27, 2011 | Samsung Televison & Video
Light spot on screen
That could be just a finger mark. Try cleaning with a soft cloth and mild washing up water.
If the mark is due to damage on the screen, it rarely polishes out and usually gets worse with polishing.
Hope you get it off.
Jan 02, 2011 | Panasonic PT-44LCX65 Television
Spilt beverage on screen and fluids are between the screens of my Samsung HLP5685W, I need to know how to separate teh screens to wipe out the spill, there is a handsized spill mark from the bottom of the...
Normaly the two screen are taped together using an axacto knife seperate the screens and use 98% alcohol to clean'em,careful to reinstall the screen exactly as removed and do not scrub very hard as they plastic and can be scratched easely.
Mar 22, 2010 | Samsung HLP5674W 56" Rear Projection...
TV SCREEN PROBLEM
It may just be that one of the CCFL tubes has stopped working, but you will need to take the whole screen apart to find out.
If you do happen to take the screen apart then please use gloves, as the oil from your hands will go onto the plastic films which are behind the lcd screen itself & you will see finger marks when you turn on the tv.
Hope this helps you out.
Regards Tom.
Feb 10, 2008 | Sony KDL-26S2010 26 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
