The indicator light "lamp replace". Lamp replaced and the screen color is still pink. Help!
    Genius:
  • 1,039 Answers
The lamp only affects brightness. If the color is not correct the lamp will not fix this. Check cables if using the color stream input. If color is off on all inputs and even the tv menu then replace the light engine. If you could list the brand and model I could give you some more helpful information.
Posted on Dec 05, 2009
How much is it to replace the lamp and how do I do it. The red light flashing for lamp means the lamp needs to be replaced for sure?
I'm sorry that the LAMP light flashing. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it indicates that the lamp of the TV needs to be replaced. Based on the information you have provided, it is the time to replace the lamp with a new one. XL2100 is the replacement lamp for the TV.
The Original Replacement LAMP costs $199 from Sony. Please click hear to order it online.
Please refer page # 16 of the Instruction Manual of the TV to get the instructions to replace the lamp.
Click hear to download the Operating Instructions if you don't have one handy.
I hope the information helpful. Thanks for understanding. Please let me know if you require any additional help/clarifications.
Aug 01, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
When i start my PC on the screen where there is pink background color their I see all pink color replaced with small - small red pixels .... I have adjust and done all possible method on Menu(Setting)...
Pink and pink streaks are a sign that the CCFL lamp is about to fail. The CCFL lamp provides the backlight to the monitor.
To confirm that the monitor is faulty and not the video card, connect a different monitor to your computer.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
May 14, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Zenith model D52wlcd projection TV has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Oct 07, 2009 | Zenith D52WLCD 52" Rear Projection...
Vertical pink line on the right side of the vaio screen
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Computers & Internet
Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
Pink color should be blue also flashing screen
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
May 22, 2009 | Acer Aspire One PC Notebook
HP Pavilion dv9500 lcd screen issues. Turns pink after warms up.
Defective CCFL backlight may has the following symptom:
  • Picture flickering with dim display.
Mar 29, 2009 | HP Computers & Internet
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
