I go to the Control Panel, click on remove/edit Programs, it then says please wait while the list populates.....but it never does! I have no way to remove unwanted programs from my computer, so my memory is full and my computer is SLOW to stop!! Is there a way to fix this or reset it so I can get there another way?? Thank You!!
Re: HELP! I cannot remove Programs from my Computer!!
Ive got the perfect answere for you and its called CCLEANER
then. follow the steps in the pict bellow... go to the one, wich is cleaner.. then click on analyze, and youll see how much garbage will be deleted (dont worry about what it will delete.. becase C is for crap.. and it will delete alot of garbage.) anyways.. if it takes too long, you could still click on run cleaner.. and it will still give you a resume of what it has done.. then, clean the registry marked by a 2... i really never make a copy of what it deletes when i clean the registry, but that is because i know what i have in my pc... then.. go to the 3 thing called tools.. and there you can uninstall programs and also stop some programs from runing at startup (be carefull with this, there could be programs at startup that you might need and might need to restart them when your pc starts if you decide to erase them, and also, you might damage something, so.. if you dont know what it is.. dont touch it!...
You could try running Add/Remove program under safe mode. To enter safe mode, press and hold "F8" during system bootup, when given a menu, use arrow key to choose "Safe Mode".
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have to remove or disable it
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. you might have to remove toolbar extensions to Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
have if dont need any of them you can disable or remove them
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. Hope this helps.
b> You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Log on to your computer as an administrator. Click Start, and then click Control Panel.
2.
Click Add or Remove Programs.
3.
In the Currently installed programs list, click the program that you want to remove. Then, click Remove or Change/Remove.
4.
Follow
the instructions that appear to remove your program. Each program has a
different process. Restart your computer if prompted.
Dear. Go to your Control Panel from your Start Up Menu. Click on Programs. Click on Uninstall Program.This will bring up the list of all the programs installed on your computer. Scroll down until you find the Program you are trying to Delete. Click on the program and follow the prompts to Delete. Look through this list and Delete any unwanted or outdated programs since they take up valuable space. Be blessed.
follow these easy steps:
1)open my computer 2)click on Add and Remove Programs ,wait till is loaded then select your program that you want to uninstal and click Remove.
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone. It's best to back up the registry in case you make a mistake. To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
Click Start, and then click Run.
In the Open box, type regedt32, and then click OK.
In Registry Editor, locate the following registry key:
In the left pane, click the Uninstall registry key, and then click Export on the File menu.
In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs
list of the Add or Remove Programs tool. To determine which program
that each key represents, click the key, and then view the following
values in the details pane on the right:
DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
-and-
UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
On the File menu, click Exit to quit Registry Editor.
Click Start, click Control Panel, and then click Add or Remove Programs.
In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
Do one of the following:
If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
-or-
If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
