Question about Poulan Garden
At full throttle and choke off, blower slows down or dies, after it's warmed up.
  • 486 Answers
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 16, 2009
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
How do I keep my Yardman bp2 leaf blower running? will idle but not come off of choke.
It sounds like a carb problem. You can buy a rebuild kit on line for cheap and rebuild it.Should run fine then.
Oct 11, 2014 | Garden
Rough idle
Sounds like a automatic choke sticking....Take the air duct loose from carb..While accelerating engine spray bottle throttle spray in.....as the car tries to die...stop spraying...Repeat 3 or 4 times.....It will clean your injectors. Runs alot better...Remember....bottle throttle spray...not carborator spray
Aug 12, 2013 | 2003 Chrysler PT Cruiser
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of...
sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Mar 12, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Echo Blower dies out when full throttle
Find the fuel air mixture screw located by the carb and turn it so the moter starts to slow down then turn it so the blower runs smoothly this should keep it from dying out
Nov 22, 2008 | Echo Garden
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Garden Logo
179 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
