Akura APL2323W-HDID LCD TV - remote control problems
The remote control of my Akura 21'' APL2323W-HDID LCD TV suddenly stopped working a few weeks ago, even with fresh batteries. Bought a universal remote and it won't connect to the set at all, which makes me think that there's a problem with the infrared reciever. Help?
SOURCE: remote control code
Hi I am trying to reprogram my Direct TV remote to cut my 42" lcd on/off , change channel, and work the volume. It did this until yesterday. I do not know if I did something or not. PLEASE HELP!!!!!@
Posted on Dec 01, 2008
ccormier007
  • 61 Answers
SOURCE: LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Posted on Jul 01, 2009
  • 668 Answers
SOURCE: I have an LG 37 inch LCD. The remote control
Most of the time it is the Main Board in the TV that the sensor plugs into. They have had many issues with this Board causing this problem. To be sure, you will need to call a professional.
Hope this helps,
Skyassoc
Posted on Jul 16, 2009
sabreusa
  • 271 Answers
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
Posted on Nov 07, 2009
SOURCE: i have a V-ZON TFT
Did you ever figure it out? I have the SAME problem! It goes on then after about 5 min, it shuts off! I checked to ensure that the sleep timer wans"t on & it wasn't. I've also been looking for a contact number; no luck there either...
Posted on Jan 21, 2011
Need sky remote code for acura APL2323W-HDID
0318,0392. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Feb 05, 2015 | Televison & Video
My akura tv remote stopped working so i bought a universal remote but i cant get this to work either
Hi Peter, we would need more info....
Model # of the TV
Are the akura codes not available for the remote?
If available is it that none of them work?
Jun 09, 2011 | Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
NO TV CODE
i only see a tv code of 10264, not a combo code
Nov 28, 2008 | Radio Shack (15-2147) Remote Control
Akura tv dvd combo remote control codes
just got sky and need a code for the remote as i cant use the volume on it
Jul 27, 2008 | Televison & Video
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Televison & Video Logo
446 people viewed this question
Top Televison & Video Experts
