Question about LG DLE2514 Electric Dryer
Wet lint and smells, takes too long to dry - LG DLE2514 Electric Dryer
    Sergeant:
    Champion:
  • 289 Answers
Try running the dryer with out the vent line hooked up.if dryer run's well than your vent line is blocked.
Posted on Nov 15, 2009
I got a burning smell after I cleaned my dryer from Lint.
I have seen this before, cleaning the actual dryer vent trap out is taking the machine apart, I mean taking the cover off and vacuuming the thing out. Just taking the tube off the bottom that goes outside isn't enough some times. We find change and bolts as well when cleaning it "all the way" usually. It could just be residual dust burning from the heat part as well. How is it drying? If the cloths are getting dry at the right amount of time, then you might be OK.
Dec 11, 2017 | Dryers
Dryer smells like it's burning
You probably have lint build up in the lint houing, you need to clean dryer by take dryer apart ,you may need to call services tech.
Feb 18, 2015 | Whirlpool Dryers
Not drying efficiently. Air moving ok, heat appears to be ok. Would like to open it up to visually inspect it. With event off slight burning smell. Would like to verify clean of lint.
If it tumbles and it heats up but your clothes don' t dry disconnect the vent tube from the the wall and run a load of wet clothes if they dry then your homes venting is clogged and if it still does not dry then it could be your thermal fuse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Mar 30, 2014 | GE Dryers
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Dryer is not drying- wet lint in the filter
Maybe you have a dead animal, (mouse,rat etc) inside of unit. They could have died whilst chewing the wiring, hence the no heat problem. Take off the panel on the back of unit or tip it on it's side. You should be able to see the inner workings and anything else. If not, buy a new dryer, this one must be costing heaps to run.
Dec 14, 2011 | Dryers
My clothes come out of the washer smelling fresh and clean. After drying in the dryer, they smell mildewy.
Check for lint buildup in the vent discharge hose/pipe and the inside of the dryer blower housing.
Heavy wet lint buildup will cause a moldy/mildewy smell that you describe.
Heavy lint build up will also increase the drying time, and it is a fire hazzard
This is a free answer, Please rate me
Oct 18, 2010 | Estate Dryers
Dryer is taking too long to dry
Dryer needs to be cleaned. Unplug, take off back and vacuum all lint out of dryer, also take off vent and vacuum inside of vent area. Then clean dryer vent from inside of house to where it exits. Make sure all lint removed. Lint holds moisture and causes dryer not to be able to release steam caused by heating wet clothes, thus clothes don't dry.
Jun 09, 2010 | Kenmore 66972 Dryer
Ge DRYER dpgt750EC2PL back wall of drum gets very hot. Occassional smell as if something starting to burn. How do I open the top lid to get inside to find out problem
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Mar 15, 2010 | GE Profile Harmony DPGT750EC Electric...
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
LG DLE2514 Electric Dryer Logo
97 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
