Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
My bissell cleaner is not picking up the solution and my my knob to switch it from carpets to tools is broken
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
refd
Posted on Sep 30, 2010
  • Pete Warnock
    Pete Warnock Dec 22, 2015
    This link doesn't work anymore.
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
Can't get my bissell deep clean carpet cleaner to
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again...
Oct 24, 2012 | Vacuums
The tools hose on a bissel powerbrush carpet cleaner leaks
Sorry to hear you are having issues with your BISSELL deep cleaner. Your upholstery hose should not leak when used. There is a small o-ring on the end of the hose that may be missing, or if the tool is cracked it could leak. A service center could better help you identify the problem. Here is a link to find your nearest BISSELL Authorized Service Center: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Sep 25, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
9500 doesn't pick up water
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is a small (1 inch square) red plastic filter with a door on it. Flip the door open and it is probably clogged with hair, carpet fibre, etc.. Clean it out and hopefully you will have suction once again.
Jun 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replace the switch that controls hand tools to the upright unit
If that flap isn't moving when you turn the knob for floor or hose, then yes it is broken, part #2136988 is the diverter valve. You will have to remove the top cover, it mounts on the underside of it.
Jul 23, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
109 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
