My sons 2003 Tatung model p 46 just stopped working. When he turns it on it makes a popping noise. Is it worth fixing?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the TV isn't turning itself on then the fault protection circuit has detected a fault and has turned down the TV. You'll need to check various things to be sure which part is bad. Please check these---
1. Check for signal cables at the back and also try unplugging the TV for 8-10 hours to reset it.
2. Swollen/bulged capacitors on the power supply board-- This happens due to overheating of capacitors.
3. If the capacitors are fine then you'll need to check for connectors on all the boards and also the fans if they are working fine.
4. Make sure the lamp connections are fine and ballast is not burnt.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Posted on Nov 15, 2009
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
2003 Isuzu Rodeo right front tire making noise when going over speed bump and loud popping noise when turning to the left
Two faults here ,one is the drive shaft universal on the end of the drive shaft and the other noise ? well could be anything and without a good look and a wiggle with a 4ft crow bar i honestly couldnt say
Jul 05, 2013 | 2003 Isuzu Rodeo
My AWD stopped working On my 2003 Bravada. It makes a clicking noise in the front end. What should I check first?
I didn't find anything re Saturn per se, but the popping could be strut bearing issues or sway bar end links. Worse during turns?---------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 06, 2013 | 2003 Oldsmobile Bravada
My washing machine (Whirlpool) stopped working. As it was working, it was making a noise that I can't really describe. Later on it stopped working altogether, now it only makes a buzzing noise. What is...
Normally it is the gearbox that making that noise, try turning the drum by hand for the full 360 degrees. if it wont turn then the gearbox is out of order and needs to be replaced
Dec 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
I have a Lady Kenmore washer - model number 7204903- when it is agitating it makes a horrible deep screeching noise -so i turn it off and on - many times until it stops - my friend thinks it is the...
i lloked up your washer and it is an old belt-drive machine. they were real workhorses, but now kind of outdated. there are not many repairmen who are willing to work on these beasts. the problem is that as one problem is fixed, another might pop up and the repairman will be expected to remedy any future problems...because he touched it. if you can locate a repairman who will work on your washer, if it is in good shape, it would probably be worth fixing
Sep 24, 2009 | Kenmore Washing Machines
Fridge not cooling and making noise
MY GE ICE MAKER IS MAKING A LOUD NOISE, HOW DO I DISABLE THE UNIT BEFORE IT BURNS UP SOMETHING
Jul 13, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
