Question about Sony Playstation 3 (PS3) Console
I have set up my ps3 on my hd television all leads are inserted correctly and ps3 is powering up but the t.v is not responding in either of the av inputs even hdmi, is there any posible answer to why it isnt working
sandrew
  • 2961 Answers
SOURCE: ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Posted on Aug 24, 2007
  • 51 Answers
SOURCE: CD SOUND QUALITY ON PS3
r video and audio set to HDMI
or try playing with the audio settings the ps3 might not be set to play the audio format
Posted on Nov 21, 2007
J4XXN
  • 182 Answers
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Posted on Jan 08, 2008
Ravege
  • 327 Answers
SOURCE: My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Posted on Aug 01, 2008
fkuk
  • 311 Answers
SOURCE: PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
Posted on May 08, 2010
Non-working ps3
hold the power button till it beeps twice , that will reset the settings , if it does come on then go to manual settings ,av settings, make sure ur tv is hdmi if u choose this option and choose either 720 dpi or 1080 if ur tv is full hd , if not do not choose these if ur using an av lead instead of a hdmi
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Ps3 won't play on my 42hds69.
plug in hd lead from ps3 to tv/now go to tv menu were you will see a choice of hd/scart/dv etc go to each till you find picture/or on remote av button/remember hd is not like a scart it does not switch ur tv to picture
Dec 26, 2009 | Hitachi 42HDS69 42 in. Plasma Television
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Does not output av to tv
use a hdmi lead and use the correct settings on the PS3..........presumably this is on a HD tv
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 lines
does the tv have hdmi? try a hdmi lead and change settings on ps3 for hd use.
Jul 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
How to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Oct 20, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
