You need to check your setup's recording volume and interface. You did not mention if you are trying to record from RCA or digital inputs.
It sounds like your recording level is not set up to catch all of the music. I'd love to buy a unit which cuts all of the whiney vocals from good trance music it is very hard to do with all of the layers of recording.
Note that you MUST use the special Karaoke disks to be able to remove the vocal... it will not do it for plain music CD's. Those devices that CLAIM to remove vocals often do so poorly... they do it by subtracting the left and right channels which ASSUMES the lead vocal is centered between the channels... Those methods don't work very well...
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality. In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
There's a multiplex button (MPX maybe) on the left front of the player. By hitting it you get leads only, background only or both. Be sure, though, you have a multiplex CD. Otherwise you'll only have background and no lead. I learned the hard way. Watch or scan for multiplex or lead vocals. Good luck...
