Question about Kitchen Ranges
Need help putting GE oven door back together again
I took the oven door apart to clean the glass and two metal pieces (about an inch long & triangular) fell out. They seem to be some sort of shim?? Two long screws won't go back in all the way either. Help!!! thank-you
  • 1 more comment
  • Anonymous Mar 14, 2008
    went to pull open oven door and it fell out. having trouble popping it back in.  how do I put it back on
  • Anonymous Apr 10, 2009
    exact same problem,thought I was so smart to get it apart - obviously not smart enough to put it back together
  • Peggy ONeill
    Peggy ONeill Aug 08, 2015
    I took mine apart to clean it and there is one piece at the bottom that I don't know where it goes. Someone please make a video!
    New Friend:
I need to know how to put the oven door parts back together on the oven door
Posted on May 09, 2011
They're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Posted on Apr 10, 2009
    works perfectly
6ya staff
SOURCE:
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to www.repairclinic.com and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
How do you install whirlpool oven door side trim pieces?
Cleaning the inside surfaces of the sealed window unit is not recommended maintenance.
Mar 01, 2018 | Whirlpool GR465LXLS Electric Kitchen Range
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Philips Toaster Oven Model HD4464/A
The glass door of an oven toaster usually are inserted in the metal slot just slightly above the hinges, so it can easily slip out and fall. try replace it with tempered glass which can be found in glass supplies
Jul 29, 2009 | Kitchen Appliances - Others
Kitchen Ranges Logo
1,109 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
