Question about Sony Playstation 3 (PS3) Console
Inserted new br disk. msg on screen is asking for an encription code. what is that?
Tip
How to unlock codes into a Blackberry 9530 Smartphone
How to Unlock a RIM BlackBerry Storm 9530 Smartphone.
1. Insert any SIM card and turn ON your Blackberry.
2. Turn OFF all the wireless connections.
3. Go Back One Step by Pressing the Back Key.
4. Go to Options
5. Select SIM card.
6. Press the Menu Key and select "Show Keyboard".
7. Tilt the phone in Horizontal Position so that the Keyboard is displayed in the Landscape Mode.
8. Type MEPD [you will not be able to see the typed info].
9. Then enter MEP2
10. Now your Blackberry will ask you to enter network MEP code
11. Enter the Unlock Code provided by us to you and Press the Enter Key on the Screen.
12. It will now say "Code Accepted'.
13. Congratulations! Your phone is now unlocked. Now your phone can be used with any GSM Network with SIM Card.
14. Go back to the Home Screen. Press the Menu Button and click on Manage Connections.
15. Turn all the Connections ON.The phone will now reboot and ''Activation Required'' will no longer be displayed.
on Feb 20, 2012 | RIM BlackBerry Storm 9530 Smartphone
How do I restore a missing OS?
Run chkdsk to repair disk errors
First of all, don't panic! If you panic and do things without thinking about consequences, you might damage your system and lose data. The solution to this problem is usually very simple. Your hard drive might have disk errors, therefore you are not able to start your system. This often happens when you restart your PC during a boot-up sequence while it's loading safe-mode for example.
1. Step Find your Windows DVD that you used to install Windows 7,8 or 8.1
2. Step Start your PC, insert your Windows DVD and hit a key when you are asked to (to boot from DVD). It is possible that you have to change the boot order in your BIOS to boot from DVD.
3. Step Follow the instructions on the screen, but don't install Windows 7, instead click on "Repair your computer":
The installer will now search for Windows installations on your PC and list them all. Select your Windows 7 installation and click on next.
4. Step Open the command prompt.
Attention: Do NOT click on "System Restore" or "System Image Recovery". If you try to restore/recover your system that way, you might damage your Windows 7 installation irreversibly.
5.You will probably be in a folder X:\sources\ . Don't worry, if your partitions are still there you can run a chkdsk on them.
Run a chkdsk for your main partition (e.g. C:), to do that enter:
chkdsk c: /f/r
This will, in most cases, repair your disk errors and you will be able to start Windows 7 again.
/f /r will both fix errors and recover lost data.
/f will only fix errors on your disk
/r will only recover lost data
May 31, 2015 | Computers & Internet
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
I need to reinstall Windows XP Professional, i.e. a so-called clean installation, on my HPCompaq dx2300 Microtower. When I insert the Operating System CD, Windows XP Professional, I get the following...
im sorry, i cant see its label , lots of CD sold are wrong..
the manual is online at HP. read page 2.
http://h10032.www1.hp.com/ctg/Manual/c00859654
the HP disk is marked HP, Restore Plus!CD
but fails to tell you in that book how to use it
that means hp has other books, on this.
we do this only if F11 fails. below
hp deleted the XP file but is same as w7
disc inserted this here
step 7 , pick cd.
id bet xp has less choices
but all have factory reset.
http://hp.dezide.com/ts/start.jsp?guide=HPSystemRecovery.net&as=true&SFS=sdoc§ion=ccweb&language=english&lc=en&cc=us&tracking=ioz9oi1o&dcsession=25814349&action=step&response=1&step=C23597.C23584&session=d9efb31f-5a5b-4c25-89fd-9bf8d2
XP way? is here. deep searches at HP finds it.
step 7 here too.
https://support.hp.com/us-en/document/bph07145
Step 1, not using CDs at all...
read how to restore the original OS
F10 and F11 keys are the 2 keys used, last 20 years
F11 is the modern key
power off, power on, hit F11 like tap tap tap
see HP OS restore pages pop up. (magic)
if the HDD was replaced this fails. in all cases
if the HDD was slammed with a MS CD, then the original
HP setups are now all gone. (whisper thanks Gill Bates)
in that case use the HP media kit.
https://h30434.www3.hp.com/
what is slammed?
http://pcdied.com/XP-sux-sg.html#slammed
where is my kit, well at HP, not here we are NOT HP
https://support.hp.com/us-en/document/bph07143e5f8dd31-b6ad-4eea-9fad-fd5be22c165e.jpg
Jul 12, 2017 | HP Pavilion dv6000z Notebook
Cant get the computer to work. a1540n, When I start it up the screen says no signal.
Your OS is hopelessly corrupted. Try a repair operation with your XP disk. If that does not do it then you will either have to use the recovery disks you have or deal with it and and reload the witch.
Jul 22, 2017 | HP Pavilion a1540n PC Desktop
I have a dv9700 hp notebook and no programs are working. Cd drive isn't recognizing disks, wireless is not picking up networks, its not recognizing lan cables, it says no audio devices are installed,...
posted no less that 3 times (corrected)
what OS? operating system ,windows,and what version please.?
this PC was built for many years, and may OS shipped with it. new. I cant guess that.
take out the battery first? and run on nice clean AC ?
carbon dating shows: 2010 year? not too old and is still supported
if still not slammed , still original, as HP MADE it
the F11 key is the magic key that reloads the unstated OS.
power on, F11,f11, f11, bam , recovery mode.
dig? if this fails then the HDD may be bad.
run he BIOS HDD test yet?
do you have the HP media kit? the install disks.?
It will only work if the HDD is good.
to recover it or reinstall the OS
https://support.hp.com/us-en/product/hp-pavilion-dv9700-entertainment-notebook-pc-series/3632106/troubleshooting
tests, there are many tests. is that what you want?
battery out.
screens are not dead. so we skip black screen tests.
BIOS works, you can hit the ESC key as it tells you
and you can boot to CD (using test CD known to work.
you can boot to any test USB stick , make stick with linux live or windows 7 PE live and boot that, see
the PC works right>?.??? simple easy tests.
if all that works then the HDD has issues.
the means what.? (more tests)
1: HDD bad.
2: HDD OS infected.
3: HDD OS corruption, use F11 to retort it per the guides.
One good these, I have many, too many.
but one good test for HDD is what.
a: run the BIOS HDD test.. fails, bingo bad hdd.
b: F11 fails can be bad hdd but not always.
Fll can fail for someone damaged the HP special partitions on hdd. (or the HDD was replaced before)
c: so use the HP media kit to install the unstated OS?
if that fails, the HDD is bad but to prove that
I convert my install cds to USB stick installs.
CD to ISO , RUFUS (iso) to STICK (ask)
if those install the HDD is ok but the CD drive is bad.
see? there are lots and lots of tests to do.
or its just guessing game...
I also have a LINUX disk with a full blown, HDD test in it to tell me if the hdd is bad. this works best.
but im not going to teach this here and now,
you must ask.
I did a long post due to you asking 3 times
you sound serious.....
but what do you want? all we see are limited symptoms.
you fix it?
or others fix it?
or guessing list.?
Jul 23, 2017 | HP Pavilion DV9700Z notebook PC
I have compaq presario CQ35.i installed vista. After few months getting some errors on Blue screen. And computer restart, getting same error many times.now when i m installing or upgrading OS, but its not...
old Cq35 (the numbers at the end are missing)
CQ35-nnnnnn what?
what OS??? VISTA sure.
What DISK no disc presented by you , 1000s it can be.
what VISTA DISK.
http://www.pcdied.com/HP-OS-GET.html
Jul 17, 2017 | Compaq Presario 1692 Notebook
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
Error messages
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Dec 01, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
