Question about Lenovo ThinkPad R61 PC Notebook
I have installed Belkin N router onto my computer, however my laptop is not pickin the signal up and I cannot connect to the internet on the laptop just the computer
    Problem Solver:
  • 18 Answers
If you do not have an 'N' compatible wireless adapter in your laptop, make sure you set the Belkin to 'B/G' compatability mode. Also, the type of security if an older laptop is probably limmited to WPA-PSK, and you would need to set that up in the router as well. Extremely old laptop wireless adapters may be limmited to WEP, which is an old an unreliable security encryption.
Posted on Nov 15, 2009
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
I think this can help you quick....
1. first connect all wire and adaptor properly....
2. open admin page of router from broswer
then click on this link. How to Setup Belkin router Install Belkin Wireless router
it seems may help you,
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
I have a Belkin Wireless G Plus MIMO Router and a Toshiba Satellite Laptop. The laptop will not connect to the wireless signal from the router. It shows it as an option on the laptop, but will not connect....
It appears that your neighbour has an unprotected wireless router setup for you (and anyone else) to connect into his router and get onto the Internet. You should suggest to him to secure his wireless router.
To connect into your own wireless router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Belkin WEB site to download this info.
You can also connect to the Internet by using a LAN cable and plug it into the Belkin router.
Sep 02, 2009 | Toshiba TR 602A (TR-602A) Router
Belkin router signal not showing up for Wii or Laptop.
If no signal, check router config. Use your
internet browser to look at router's settings.
By default the password on most Belkin routers is left blank, and the default IP address is 192.168.2.1 Check all you router's wireless settings in case disabled or incorrect. Make sure the laptop's wifi button has been toggled to OFF. Routers do die - esp the lowend ones. New wireless G router = $20 on sale.
Jul 07, 2009 | Belkin (F5D5231-4) Router
Will not log on to internet
belkin router F5D7230-4
wireless works fine, anything plugged in gets cut off after a few minutes.
Dec 14, 2008 | Belkin (F5D7230-4) Router (587009)
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Not pickin up signal
Upgrading the firmware (which forced a software reset) solved a similar problem I had with an SMC router. Have you tried logging into your router via an ethernet cable and doing a software reset? If you try this, be sure you have all the information you need to set up your wireless network again because the reset will wipe out all this information.
Nov 12, 2007 | Belkin (F5D7230-4) Router (587009)
Lenovo ThinkPad R61 PC Notebook Logo
133 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
