Question about Palm TX Handheld
Palm tx reboot when office documents is selected
Just got palm tx 2 weeks ago, was fine at first, then every time I touch office documents on the screen the palm tx reboots.Have not added anything to unit (hardware or software) that did not come with it. Have loaded 6 pictures, 3 spreadsheets, 1 document and some contacts phone numbers on unit. Have since unloaded every thing that was loaded, but prob. still there.
  • Anonymous Jan 10, 2008
    i have the same problem and haven't come up with a fix yet! 4 months of trouble!
  • Scott Tokiwa
    Scott Tokiwa Dec 21, 2008
    added Arcade Park to my T/X and now every time I try to open the documents to go ,it reboots
6ya staff
SOURCE:
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
Touch screen not precise/not working properly
ttry calabraiting the screen that may help a little i think it will be under pref
Mar 26, 2009 | Palm TX Handheld
Word and excel document transfer
I'm afraid so. Documents to go uses a seperate converter program that work with the desktop installer program. That way you change documents on you Palm as well. I know mine was pretty pricy when I added the database system for Access files. That was the main reason why I needed it at the time.
Just got a Blackberry a few weeks ago and was surprised at the pricetag to do it. I think it was running $75.00.
Oct 25, 2008 | Palm TX Handheld
Installing palm on new computer
There is no way to download from a PALM. The only option is to syncronize or sync different programs. You will need to install the original program that created the database for the palm, and then set that program to sync to to PALM.
--Randy Miller
Aug 27, 2008 | Palm TX Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
WiFi Icon on Palm Tx not showing on taskbar
You should try reloading the software back into the TX. In order to do it, you will have to erase your TX memory. Make sure you back up your files first.
To erase the memory press the reset button until the reboot screen appears. Hold down on the power button until the erase memory screen appears. Select yes. Reload software from Palm CD.
Jun 05, 2008 | Palm TX Handheld
Email errors
I would erase the TX memory and reload the software.
The TX memory can be erased by pressing the reset button in the back of the unit while holding down on the power button. Press yes to confirm delete.
Reload Palm software from CD.
May 19, 2008 | Palm TX Handheld
Palm TX reboot
What happens when you press the reset button on the back of the TX?
May 13, 2008 | Palm TX Handheld
Palm Reboots when on Internet
Apr 15, 2008 | Palm TX Handheld
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Palm TX Handheld Logo
151 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
