Question about Motorola Mobility RAZR V3
When you flip phone open inside screen stays white intell you power it down.
Why does my phone screen stay white?
it will be alright after 30 days. Be calm and quiet.
Aug 11, 2012 | Samsung C3050 Cell Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
My phones screen turns white and takes long to go
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 18, 2010 | Motorola Mobility Rival A455 Cell Phone
The screen is all white and when i flip it open
just make sure that your phone is original and not a china phone!
Feb 09, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
My screen is white
sounds like the lcd screen went bad due to water danamge/humitity. problems with water damage is they can start rite away or several month down the road. if you have phone insurance, use it.
Sep 13, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Open/closing diaplay problem
replace your phone
Oct 07, 2008 | Cell Phones
Ds lite top screen problem
My ds has the same problem, except it stays white! but only because the cords on the left side of the ds (bust the part where the two light indicators are, power and charging, and slide the top screen to the right, then you should see the cords.) are not connected ore are lose from the central part of the ds. Ask nintendo or somebody who is a whire repairer to connect these wires.
Aug 07, 2008 | Nintendo DS Lite Console
Screen gets distorted and turns white
the flexcable need to be replace on the phone
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
