Question about Canon PowerShot S5 IS Digital Camera
All memory cards are locked when inserted cannot figure our how to unlock
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Slide the tiny switch on the side of the cards to their other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Nov 15, 2009
Needs to remove write protection
On the memory card adapter there is this a lock that pulls up and down to lock and unlock the adapter once SD card is inserted in the adapter, when you insert the adapter into the P.C make sure the lock is on unlock and then insert it to computer and the write protection will be off. do that again when you want to insert your into the computer again.
Feb 03, 2012 | SanDisk 4GB microSDHC Memory Card
My micro sd card lock how can unlock micro sd card
Locked Memory card.
Note:- Locking of memory card is a RANDOM process.(means it gets locked on its(memory card) "OWN')
1.Whenever a card gets locked,its mainly due to the following reasons.
(I)When you insert it into a uncompatible mode.
(II) when some unsupporte files are placed.
(III)When its for specific mobile.
100% working solution for LOCKED MEMORY CARD is :-
1.Use Unlocker(its like a pendrive device with 9V battery ),and its IC is programmed in such a way that it tests every possile code.
2.The one that sets mades the memory card Unlock.
3.BUT you cant know what the CODE was.
4. Data can NEVER be retraced.
Noye :-Buy an Unlocker available @ Rs.200.But you may not get the same problem often so take it to the retailer it will costaround Rs.20 for unlocking .
Aug 29, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
Memory card unlock
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
Jul 08, 2010 | Nokia 5310 Cellular Phone
My memory card is locked
Good day!
Locked..You mean write protected?I think there are instructions on how to unlock it.
Anyway, Try this:
There is a slide unlock/lock switch in the side of SD card. Its up and down switch that on and lock the card.
If you're using a mini card try to insert it to standard SD adapter.\
regards,
Mastergani
Jul 06, 2010 | SanDisk 1GB microSD Memory Card
My Memory card has locked after formating my Ohone momory.
A standard "unlock code" for memory cards would be something simple like 0000.
Nov 08, 2008 | Nokia N70 Cellular Phone
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
