Question about Jandy Aqualink Rs4 One Touch Control System Control System
Wall control light flickering Jandy Aqualinks RS
Wall control light flickering Jandy Aqualinks RS Everything else working fine
  • David Spradling
    David Spradling Apr 16, 2016
    check 4 pin red connector see if loose
    Top Expert:
  • Jandy Master
  • 6,394 Answers
Check the red 4 pin plug could be loose
Posted on Mar 05, 2016
SHANEOK
  • 21 Answers
SOURCE: where are the water& air temp sensing low
there should be a diagram on the inside of the jandy box.#5,6,7,8 on the terminal bar.
Posted on Oct 02, 2009
Testimonial: "saw T.bar but no wires least I know where they go"
  • 246 Answers
SOURCE: Jandy aqualink RS handheld went out during
GO TO THE MAIN PANEL AND RESET THE SYSTEM
Posted on Oct 13, 2009
  • 246 Answers
SOURCE: I have this jandy aqualink one touch rs control in
GO TO THE MAIN PANEL AND OPEN IT DISCONECT THE SPA SIDE SWITCH LEAVE OFF AND SEE WHAT HAPPEND FOR A FEW DAY IF OK REPLAACE SWITCH
Posted on Oct 15, 2009
fixyourboard
  • 310 Answers
SOURCE: select button on Jandy Aqulink rs does not work
We have been repairing quite a few of these controllers lately. Much lower cost than replacing the boards. Best Regards, bruce@fixyourboard.com
Posted on Jun 19, 2010
  • 84 Answers
SOURCE: On Jandy Aqualink RS display it says 6700 Rev C
If you bypass the 4 wire cable wire as described by 'the californ', and the problem persists, there is a problem with the control boards. Either the PowerCenter board or the RS remote board. We see this failure alot. It is usually due to a a problem in the RS4/6/8 electronics but in some cases it is the PowerCenter. They can be repaired at a fraction the cost of new at www.fixyourboard.com. You can send the remote unit first since all the pool functions will remain and they can test it for you. If it is ok, you will have to send the PowerCenter.
Posted on Nov 01, 2010
Why does my aqualinks pool panel beep
do you have a aqua pure chlorine generator if so turn to 0 until water is balanced
Jun 15, 2013 | Jandy AQUALINK RS TELELINK KIT
Aqualinks rs8
go to jandy site they have PDF files you can download or they will send you one go to system set up go to clear memory clear memory then reset button on front of aqualink panel that will loose everything
Jun 10, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy rs4 indoor control panel lights up but nothing displays
trade controllers if when switched problem moves bad controller if problem stays inside bad wires or plug
Aug 18, 2012 | Jandy Aqualink Rs4 One Touch Control...
Aqualinks RS4 pool light button will not turn off. Has 6522 REV 1 on screen
bad light relay what ever aux it is replace it it is stuck on you can turn off breaker for light in temp fix
Oct 10, 2010 | Jandy Aqualink Rs4 One Touch Control...
M rs wall unit barley lights up.can the light be
go to menu/display light/on off leave at 2 min delay if this doesnot fix let me know
Sep 12, 2009 | Jandy Aqualink Rs4 One Touch Control...
One touch display light is flickering
You have a simple short. Check the wiring. A loose wire on the comport will do it.
Jul 12, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
193 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
