Question about Connex 3300 240-Channels Base CB Radio
I need to tell what channel i'm on there's 240 channel's i can only reconize 40 of them
    Guru:
  • 773 Answers
Purchase a frequency counter. They are usually cheap. Try ebay. Get one for under $50.
this will give the the frequency you transmit on when you key it.
Posted on Nov 20, 2009
What channels are legal to use on a Connex 3300 with 40 upper, lower and regular settings?
only the CB band to TX on.. you may RX on any frequency.
ch.1-ch.40 am and SSB if it had it.. are the FCC allowed channels. yes there are people on those other bands. user beware.
Feb 08, 2014 | Connex 3300 240-Channels Base CB Radio
I have a galaxy dx33hml with 120 channels. im trying to make sure its on regular channels. How do i do this?
If you've expanded the frequency coverage, you should have 240 channels, not 120. If that is the case, the link provided will give you the band plan, and shows you which settings the standard CB channels are on.
http://www.cbtricks.com/radios/galaxy/dx33hml/dx33hml_band_chart.htm
Jan 20, 2014 | Galaxy Radios DX-33HML 40-Channels Base CB...
Tabla de frecuencias
CB Radio Channels (FCC)[32] Channel Frequency Channel Frequency Channel Frequency Channel Frequency 1 26.965 MHz 11 27.085 MHz 21 27.215 MHz 31 27.315 MHz 2 26.975 MHz 12 27.105 MHz 22 27.225 MHz 32 27.325 MHz 3 26.985 MHz 13 27.115 MHz 23 27.255 MHz 33 27.335 MHz 4 27.005 MHz 14 27.125 MHz 24 27.235 MHz 34 27.345 MHz 5 27.015 MHz 15 27.135 MHz 25 27.245 MHz 35 27.355 MHz 6 27.025 MHz 16 27.155 MHz 26 27.265 MHz 36 27.365 MHz 7 27.035 MHz 17 27.165 MHz 27 27.275 MHz 37 27.375 MHz 8 27.055 MHz 18 27.175 MHz 28 27.285 MHz 38 27.385 MHz 9 27.065 MHz 19 27.185 MHz 29 27.295 MHz 39 27.395 MHz 10 27.075 MHz 20 27.205 MHz 30 27.305 MHz 40 27.405 MHz
Oct 18, 2013 | Connex 3300 240-Channels Base CB Radio
After you convert the connex 3400hp from ham to amature, what do you do to tune it in where you can reciever and talk? and also how do you tell what channels are regular,uppers,and lowers?
you will need a frequency counter, to show the channels. 1-40 and the others are allocated as frequencies. there are lists available showing ch1 band A is ??? so forth. there shouldn't be uppers or lower on it its just a AM/FM only radio NO SSB.
and these ARE NOT AMATEUR / HAM radios!!!!!!! these are EXPORTS...
Dec 12, 2010 | Connex 3300 240-Channels Base CB Radio
I purchased a 3300hp for my truck how do i set the dials for just cb use
your mic gain and rf gain keep all the way to the right at all times.d/a is where you need to be for your basic 40 channels with your band switch on hign. echo ussally around 11 o'clock for both nobs. leave you nbla switch all the way up.tb is your talk back, if you want to hear yourself turn it on.
May 02, 2010 | Connex 3300 240-Channels Base CB Radio
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
Connex-3300 General question on what d/a, e/b, f/c stand for?
The letters are four different bands;for each letter you have another 40 channels.Good Luck
Apr 10, 2009 | Connex 3300 240-Channels Base CB Radio
Fresh install SWR will not come down
have you checked the coax connectors? It's gotta be a bad connector,damaged coax or a defective antenna. Careful--don't test "too much" or you'll burnout the final amp!
Dec 27, 2008 | Connex 3300 240-Channels Base CB Radio
Standard Microphone Wiring
Pin 1 is Shield(most mics this wire is bare copper) Pin 2 is Audio wire(most mics this wire is white) Pin 3 is Transmit(most mics this wire is red) Pin 4 is receive(most mics this wire is black)
May 30, 2007 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
77 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
