Question about Hotpoint Ultima WF860 Front Load Washer
Screen display reads f-08 - Hotpoint Ultima WF860 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
  1. Error code F08 indicates heater relay stuck
  2. Check pressure switch connections
  3. Check heater connections
  4. Check module connections.
  5. Check pump and or pump filter for blockage.
Please rate ,my solution.
Thanks.
Posted on Nov 16, 2009
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
What do I have to do to get proper depth readings on my hummingbird 561. Instead of reading 4ft it reads 08
read the user manual as to how to calibrate the unit
remember that it reads the distance from the sender unit to the sea bed/river bed and not from the display unit
May 28, 2015 | Hummingbird Boating
Don't know how to use aux option in 08 s550 ME Benz
First, you should locate the aux button or touch screen display for the aux and press it. If it reads no aux available or something similar then your model has the button but not the aux input itself. If it reads not connected, look for the aux port (looks like a headphone jack) in the center console region. after plugging in your device, simply hit aux and enjoy!
May 02, 2011 | Car Audio & Video
Error 08 / Disk Locked error
With help of Yamaha tech staff, I inserted a business card under disk "lid" in bottom left corner, slid card to right to release catch. With catch released, pushed disc in to insure in OK, closed lid cover, then slide card from lower right corner to left to re-catch. Read disc OK.
Jun 12, 2009 | Audio Players & Recorders
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Display screen cracked
go to home and click on settings then scroll and you will find it
Apr 08, 2009 | SanDisk Sansa Clip MP3 Player
Error message on print screen of 114 08
The book says nothing about this error except turn off machine for 30 seconds and try again. If this dosen't work try unplugging machine, removing the batteries and then restart. CAUTION THIS WILL CLEAR ALL MEMORY!
DicktO
Jul 29, 2008 | IBM Wheelwriter 30 Typewriter
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
Hotpoint Ultima WF860 Front Load Washer Logo
582 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
