Question about Sony Playstation 3 (PS3) Console
Will no longer read any discs - Sony Playstation 3 (PS3) Console
Can't read the disc
Well the disc's might be scratched or dirty so try cleaning the disc's with a soft cloth and cold water and next check to see if there are any scratches on them if the disc's are severly scratched at a point where the wii can't read then. Or it might be the disc drive then. Go with the old consoles they live longer and don't break down as fast gamepacks live longer than disc's do.
Jun 25, 2011 | Nintendo Wii Console
The console says "the disc
Hi there!
It could be possible that your disc is already damaged. The system can no longer read the data on the disc. Have you tried using a different disc? Did it work or was the system able to read it? If so, your disc could have already been damaged.
Hope this helps!
Jan 31, 2011 | Sony PlayStation 2 (PS2) Console
Not reading the disc when inserted. Any disc.
The problem is that the lens of your ps3 is weak that it can no longer read any disc, i advice that you replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading the disc.
Take care.
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Wii can no longer read the netflix disc. the
is it reading other games. if yes have you cleaned the disc. if not request a new one.
Jun 13, 2010 | Nintendo Wii Console
It will no longer read the disc. it seems it does seem to know a disc is in the machine
If your system is no longer reading the disc then you need to stop the heat getting to the drive, you can do this with a proven guide or send it in.
Dec 13, 2009 | Microsoft Xbox 360 Console
DISC READ
It's now Ok ???? changed 5 discs, same message, with No 6 disc OK
and previous ones work also. Beats Me !!!!!
Thanks
Oct 22, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
DVD Couldn't read my dvd
Try this
  1. Switch on (with no disc)
  2. Press DISC/MEDIA
  3. Wait for "no disc" message
  4. Press DISC MENU
  5. Press 1, 5, 9 slowly
  6. Enter 222 222 005 255
  7. Press DISC MENU
  8. Wait for "done" message
  9. Press STANDBY
Oct 12, 2007 | Philips MX5800SA System
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
