Question about Samsung SGH-G600 Cellular Phone
Just changed the lcd screen samsung g600,i damaged the flex ribbon connector and it wont turn on would a new ribbon solve this
My samsung s8300 mobile touch screen is not working, numeric keypad is working & on screen pannel only end button is working.
i bought this and solved the problem. NIKOS GREECE...
http://cgi.ebay.com/Samsung-S8300-Repair-Part-Ribbon-Flex-Cable-Tools-/380284533936?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D738272505495324217
Jan 16, 2011 | Samsung S8300 Ultra Touch platinium-red...
My cellphones display would not turn on
If your phone turns on and the display will not come on, then it means there is a problem somewhere. If the screen looks damaged, then it means the screen is bad and need to be replaced, but if the screen does not look damaged, then it means the flex of the phone is bad.
The flex is the ribbon that connects the screen to the main panel of the phone. If it is bad, then the solution is to replace it with a new flex. But if the screen looks damaged, then you need to replace the screen with a new one.
To replace the screen is simple but technical, so you will need professional hands in handling this, if you do not feel comfortable doing this yourself, follow the steps below:
  1. Remove the battery, back cover and your memory card.
  2. Now remove the front cover by running your fingernail around the join.
  3. Remove the six screws you can see.
  4. Now lift the circuit board from the chassis of the phone.
  5. Turn the circuit board over. You now need to remove the small metal box, indicated by the screwdriver, which covers the connector from the LCD screen. Pry it away with your fingernail.
  6. You should now have this metal part removed allowing access to the ribbon connector(if you are replacing only the ribbon connector, that is it)
  7. Turn the circuit board over again and lift the metal frame, which holds the LCD screen, away from the phone, allowing you to unplug the connector. It attaches like a plug and socket. Simply lift it upwards to unplug it.
  8. You should now have the metal frame and LCD screen removed.
  9. Now lever apart the edges of the metal frame to release the LCD. You can now replace the LCD screen with new. Reverse the whole procedure for reassembly.
Hope this helped.
Jan 07, 2011 | Nokia 3110 Cellular Phone
LG display is completly black, however the phone works
The problem is either in the the flex ribbon connector, connector terminals or LCD itself. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested. If no result, LCD is damaged, replace it.
Oct 18, 2009 | LG Shine CU720 Cellular Phone
My samsung blast does not have water damage but the screen works intermittently what is the problem?
The problem is in the the flex ribbon connector or in the connector terminals. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested.
Oct 18, 2009 | Samsung SGH-G600 Cellular Phone
My samsung phone is showing only a blank screen
well mayber the flex(ribbon) connecting your lcd to the board is damaged try replacin it with a new one.
Aug 16, 2009 | O2 Samsung SGH-E250 Cellular Phone
SGH-T429 screen stays blank or dark
Friend, the problem is your LCD it maybe broken if it is then you need to replace it, and if not the flex connector is disconnected try to press tighten the LCD connector slot.to solve your problem
Jul 07, 2009 | Samsung SGH-T429 Cellular Phone
LCD screen -White . Doesnt show instruction when using function
You LCD is not making proper contact with the camera board that the flex cable plugs into or you have a bad flex connector. A LCD has 2 part, the actual image and the backlight. All you are getting is the backlight with no image. You camera will have to be repaired to see if reinserting the cable into the flex connector will solve the problem.
Jul 02, 2009 | Canon PIXMA MP520 InkJet Printer
DX6440 LCD screen is Black
As I suspected, the flexible circuit board which connects the fluorescent back light to the power source was severed. Although it didn't appear broken at first, the LCD came on as I poked the flex board. I removed a small amount of insulation and reconnected the two copper leads. Problem solved.
The flex board I speak of is an amber colored ribbon; it can withstand high temperatures and is quite durable. There are two copper leads embedded in the ribbon. One end of the ribbon is sealed within the LCD, the other end terminates in a locking surface mount connector. You can unlock the connector by pulling back on the little brown latch. If you have a severed flex board, be extremely careful in repairing the connection. Once you begin removing the amber coating, it becomes fragile.
Jan 15, 2008 | Kodak EasyShare DX6440 Digital Camera
Help!!
SGH-D500 white screen'
when you turn on your phone and the screen is white' even you restarts and nothing change' make sure that your phone is can recieve and you can make a call' the prob. is the flex ribbon of your phone, there is a flex connected in the LCD to the board' or the machine. D500 phone always having this prob, all sliding and flip phone having this prob.
by replacing the flex ribbon' you can solve your prob.
by a skilled cellular technician.
Jan 06, 2008 | Samsung SGH-D500 Cellular Phone
D500
faulty flat cable that connects lower and upper part of the phone...
Aug 26, 2007 | Samsung SGH-D500 Cellular Phone
Samsung SGH-G600 Cellular Phone Logo
145 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
