Question about Dell Dimension 4700 PC Desktop
After running for a long period of time, my computer starts making a clicking sound. Then it goes to "blue" screen. I was told to make sure my fan was running when the computer is started. I have noticed that it does not.
  • michelle_bra Nov 15, 2009
    Where do I go get a fan and what should I expect to pay?
    Problem Solver:
  • 19 Answers
First thing replace your fan. if your computer shuts of, then the mother board has a fail safe when your cpu gets too hot. if that doesnt stop the clicking noise then its your hard drive, get a new one pretty soon or back up all your data.
Fans a very important in a pc, heat will destroy a computer this is why servers are placed in a controlled environment.
Posted on Nov 15, 2009
Testimonial: "thank you.."
Crash to no turn on and bilking caps light
For BSOD try following steps that might can help:
Check the cables of VGA, Mouse , Printer , Scanner and Keyboard for loose coupling at the back of computer box.
Determine if you changed anything recently.
The most common cause of the Blue Screen is a recent change in your computer's settings or hardware. This is often related to new drivers getting installed or updated. Drivers are software that allow your hardware to communicate with Windows.
Check your computer's internal hardware. Sometimes, a poor connection inside the computer can cause a Blue Screen. Open your case and check to make sure that all the cables are firmly connected and that any cards are seated firmly in their sockets.
This is more difficult for laptops. You can check the hard drive and the RAM to make sure that they are connected properly. Remove the panels in the back that cover the hard drive and RAM with a small Phillips-head screwdriver. Press the components firmly into their connections. This step is not recommended due to damage in customer device risk.
Check your computer's temperature. Overheating can lead to your hardware malfunctioning. One of the most common components to overheat is the graphics card. In BIOS post test the computer shows on black screen at start up the temperature conditions of computer box. To check it customer can restart the computer and on first screen top right or left corner will show the information of temperature. If it is more than 40 celcius then it is more likely to crash the computer. Reseat the computer in a more cooler place i.e top of the table and away from the wall for venting purpose. The malfunction of processor fan can also be the reason.
Test your RAM. A common culprit in system crashes is a bad stick of RAM. When RAM fails, it causes the system to become unstable. Open the box unplug it from the Slot Remove the RAM clean it for carbon and dust particles and plug it back on make sure when you plug it back you hear the click sound.
Test your hard drive. Run the "chkdsk" function on your hard drive to scan for errors and fix potential problems. A failing hard drive can cause Blue Screens due to corrupted files. To run chkdsk, open command prompt and type CHKDSK entre.
Strip your computer down to the essentials. This is possible on desktop pcs that take out all hardware including hardisk, keyboard, mouse etc and start plugin them one by one until error comes again.
Oct 07, 2013 | Dell Computers & Internet
Acer Aspire 9110 problem
Sounds like your video is bad or the laptop is not getting power from the ac adapter or battery. Make sure your ac adapter power cord is good.
Mar 27, 2012 | Computers & Internet
My windows crashes to blue screen
You have a fragmentation problem and that is easy to do. Start your system by making sure it goes on Safe Mode. Once it goes to Safe Mode with Networking then run the Scan Disk and Defragmenter if running Windows 98 and XP. Win 7 has it in the Administration tools in which you would have to go to the Computer management page and start the application from there. At the same time see if you can download drivers for your system so when you restart the system it will run normally and it won't freeze or crash to a blue screen.
Blue Screens can appear only if there's been a hardware change to the system or it's on another system that isn't configured for the motherboard it was originally using. So make sure it's the same system that you were using or would have to find the system that the hard drive was installed and shifted to another for various reasons. The system could have been on eBay or Amazon so make sure it wasn't sold recently.
If it is then you would have to download the drivers for the motherboard that you are using and install them.
Then see if you get a blue screen.
Aug 26, 2011 | ASUS Computers & Internet
Will not load OS stops on error blue screen
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your computer hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the central processing unit
try uninstalling a few unecessary programs also you might not have enough RAM random acess memory to check what is running when your computer is running scroll to the bottom of your screen toolbar right click select task manager applications and processes if you see something you dont need running select end now
to check how much ram you have click start right click on my computer select properties you will see all of your computers details
then you should defragment your hard drive click start all programs accessories system tools you should see the disk defragmenter
http://download.cnet.com/ccleaner/
hope this will help you
Jun 20, 2011 | EliteGroup 848P-A Motherboard
The cuputer goe on but the screen is blue , i have done what the told me to do in the owner's manuel ,but the screen stay blue
Sounds like the "blue screen of death" if your running Windows and there is text. If it's just a blank blue screen your monitor may be going bad or your can try checking the connections on the monitor and your computer.
Please let me know if this does not fix your problem or you desire more information.
Apr 26, 2011 | Computers & Internet
After driving for long periods of time the van starts running hot and the temperature gauge goes up what could be the problem?
Check to make sure the coolant level is good,and make sure the cooling fans are coming on after a while,like when it gets to normal temp.
Jul 03, 2010 | 1991 Mazda MPV
Dell 3008WFP monitor cut out after 2 or 3 hours use
sounds like a over heating problem, if there is any fans make sure they are tunring , make sure no vents are coverd on back, hover any dust from any of these areas. if continues you might be looking at a repair job.
Nov 29, 2009 | Dell 3008WFP Monitor
Blue screen error and intermittent restart issue
before you update bios, sounds like there is a problem with something getting hot inside your computer. check, proccessor fan. make sure it is working properly and the heatsink is attached correctly. other to check is video card, if it has fan on it, make sure it works. sometimes if you add an extra fan to blow out hot air from case it helps. the computer will go to shutdown if it senses high heat on any of the components on motherboard.
when you resolve this then goto your motherboards manufacturers website and download latest bios upgrade, usually is a self executable file. run it after save to your computer and it will upgrade your bios.
Apr 14, 2009 | Computers & Internet
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Unanounced system shut down
The next step that I would recommend is to use the Admin Tools in the Control Panel and select Event Viewer. Check out each of the three logs and see which one has an event with the red X at the time of the shutdown. High light it, and you should be able to see what program, if any, caused the problem. That should give you more information that may be more specific and help you track down the actual culprit.
Jan 30, 2006 | EliteGroup PT800CE-A Motherboard
Dell Dimension 4700 PC Desktop Logo
89 people viewed this question
Alun Cox
