Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp 220 Does not feed paper correctly.
I have a canon pixma mp 220 and when i go to print something the paper never feeds through printer straight. the roller on right side of printer catches more of the right side of paper so the paper always comes out a little crumbled up and the actual print is not straight on the paper, always a little bit diagonal. Is there anything i can do to fix this problem. Can you help. Kind regards. Printer is Pixma MP 220/210 series.
  • 29 Answers
SOURCE: canon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
SOURCE: CANON PIXMA MP 210
The MP210 does not support Win98 so you won't ever find the perfect driver.
Posted on Apr 25, 2008
SOURCE: canon Pixma MP 210
it seems like ink is everywhere inside on the right side and the pics that are printed are bad
Posted on Sep 24, 2008
  • 523 Answers
SOURCE: cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Posted on Mar 11, 2009
old marine
  • 1992 Answers
SOURCE: Lost Instruction book,Canon PIXMA MP 210
You can download the manuals for the MP210 here.
Posted on Mar 23, 2010
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The paper starts to feed on the canon pixma mp 160 but when i try to print or copy, paper doesn't continue to feed and I get an E message. any suggestions
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-7
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer is not feeding the paper through but acts as though it is printing
hi,
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon pixma mp 610 printer paper feed making loud noise no feed
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Canon pixma mp 160
After you remove the paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon pixma mp 530 . When the command is given to print and there is paper in the feed chamber the system energies but the paper no longer feeds,the alarm message lights and the message comes up...
your machine needs to be serviced as something like dust or any other object is blocking the gears in the paperfeeder tray to rotate frequently.
it will cost u near to $20 for geting it serviced.
Oct 01, 2008 | Office Equipment & Supplies
Printing a document on a pixma ip200
you may need to change the paper source in the printer setup for whatever is printing
Mar 18, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
258 people viewed this question
old marine
old marine
