I RECENTLY BOUGHT AN EMACHINES ET-1810-01 AND CANT FIGURE OUT HOW TO OPEN TO THE BACK BACK PANEL TO CLEAN OUT THE DUST
  • 557 Answers
You should simplly have to remove to screws on the right rear(looking from the back) and sliding the side cover off.
Posted on Nov 15, 2009
Can i clean my own sawing machine ? I own different machines and i can easily open en clean , i cant figure out how to open this one
The older mechanical machines are easy to open, clean, and lube the internal workings.
Computerized machines are pretty well self-contained. Other than cleaning the bobbin area and feed dogs of stray threads, lint, and dust bunnies, and if directed apply a drop of oil to the hook, there is not much else an owner should do. Of course, it is recommended that it be serviced every year.
Mar 21, 2017 | Sewing Machines
My computer suddenly starts racing like it was speeding. It starts and stops continously
Clean the dust from around the fans, the vents, inside the computer and around the cpu and heatsink. Take a can of Compressed Air, remove the power cord, remove the case and blow the dust out. The dust is making the fans work harder.
May 25, 2012 | E-Machines eMachines Desktop PC
CANT GET 5.1 SPEAKERS TO WORK
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
Open up your computer
the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 20, 2012 | E-Machines eMachines Desktop PC
I have an Emachine ET1331g. How do I open the casing to reveal its inner contents?
The eMachines ET1331G desktop computer uses the eMachines NexGen 3 computer case.
Looking at the computer from the Front, the Left Side Panel removes.
Looking at the back you will be viewing the Right side.
There are two screws to remove, then the side panel is slid Back. (Towards the rear of the computer)
There is a raised protrusion in the middle of the Side Cover on the back. This is where your fingers go to pull back on the Side Panel.
There is one screw coming down from the top, on the edge of the Side Panel, and one screw coming up from the bottom.
(Philips head screws)
Remove them.
Slide the Side Panel back. It will only slide back so far, as there are tabs coming from the Side panel, into slots of the computer case.
Once it stops sliding back, take it straight out to the side. Lay the Side Panel aside.
Here is a photo detailing the back of the ET1331G from eMachines Support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The two screws on the Right side, as you are viewing the computer from the Rear, as shown here.
NOTE*
1) Computer UNPLUGGED from power
2) Observe Anti-Static Precautions BEFORE reaching inside the computer, and BEFORE handling hardware parts.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components in a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
For additional questions please state in a Comment.
Regards,
joecoolvette
Nov 19, 2010 | E-Machines eMachines Desktop PC
Need Graphix, lan, 10/100 network, and multi media drivers for Windows XP pro
Try going to the web site for eMachines, since they bought Gateway a while back. They should have support for Gateway machines on a tab, making it easier to get documentation, parts, drivers, et al.
http://www.emachines.com/support/options.html
Cheers!
-a.
Jun 01, 2010 | Gateway E-2000 Deluxe PC Desktop
Computer ramdomly shutting down
Hi there.
It sounds like the system is overheating.
Open the side panel and remove all the dust that you can see, a clean dry soft paintbrush should do the job, make sure you clean the CPU fan and heatsink (the metal block behind the CPU fan).
Once that's done the computer should stay on all the time but remember to clean the insides of the case periodically to prevent this problem form arising again.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | E-Machines eMachines Desktop PC
EMachine Desktop Computer
Hi there.
Remove the power cord from the back of the computer, take the side panel off the computer so you can see the motherboard, take out the system memory, looks like this >>>>
get a clean, dry soft paintbrush and clean the brass contacts and the slots that the memory (ram) goes into of dust and any other foreign objects.
When you are satisfied that all the dust has gone reseat the memory back into the slots making sure they/it clips into place nice and tight, put back the side panel, plug the power cord back in and try to restart the PC.
Good luck and thanks for using FixYa!!
May 24, 2009 | E-Machines eMachines Desktop PC
I have to clean my N73 screen
just take it to any mobile repair shop ,and he will open the front panel of your mobile and will clean the dust,if mobile body is damaged replace your mobile body..
or : If you know how to open the front panel of your mobile it will save your money,just use clean cloth to remove dust....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Nokia N73 Cellular Phone
Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
Dec 18, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Computers & Internet Logo
498 people viewed this question
David Payne
David Payne
