Drum not spinning belt in place and seems in good order
  • 725 Answers
Contact us with the brand and model number and we can diagnose this issue for you. We also have parts for all major appliances and would love to help you get this repaired.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we will help you. Thanks, Ella
Posted on Nov 17, 2009
My dryer spins but barely, it seems to be scrapeing on the bottom? Any ideas how to fix?
Possibly loose belt. Mostly the belt tensioner is come off or its mounting screw came loose.
Try this:
Unplug the power.
Open the top lip (cover) . Open the front panel.
Check the tensioner under the drum. The spring must stay in place. All the mounting bolt or screws must stay in place.
Check the belt. if it's tear off or expend too long then possibly need new one.
Good luck
Mai
Feb 08, 2017 | Dryers
My dryer tries to spin the drum when you push the start button but seems like it's having a hard time. If I spin it by hand it will start and run for about 5 to 10 minutes then shuts off and seems to
I would first check the belt, then check the belt tensioner, and finally the wheels the drum rolls on. You will find a worn belt, or worn or out of adjustment tensioner, or wheels that are worn at their axels. GOOD LUCK FRIEND.
Jan 16, 2015 | Whirlpool Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW 1967 has broken. Is there a step by step guide on how to fit the replacement belt.
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Jun 23, 2011 | Dryers
Howdy, I have an old spacesaver washer/dryer and everything works but the spin cycle. The belt burnt a couple days ago because I may have put too much laundry into the machine. Now the clothes come out...
the belt is probably coming of because the bearings in the drum are shot and if thats the case you might as well by a new one cause its so expensive to do a bearing job you can spin the drum around by hand and back and forward to see if its spinning smoothly if it seems ok then get a belt from your local appliance spares place and put it on yourself.
Jan 05, 2011 | Washing Machines
The drum won't spin or agitate the cause is the belt slipping off
There is a mechanical alignment problem beyond your ability to fix. Get a repair Tech and pay for a service call.
Oct 24, 2009 | Washing Machines
Neptune MAH3000AWW Pullys dont line up
Found that the rear bearing was bad, did not want to spend big money on very old machine so just replaced it.
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
